Introducción
Once the battery and case back cover have been removed, the motherboard can be accessed as shown in this guide.
Partes
No se requieren partes.
Slide the cover release button towards the bottom of the phone Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
  • Slide the cover release button towards the bottom of the phone
  • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
Agregar Comentario
Push the battery towards the top of the phone and lift up.
  • Push the battery towards the top of the phone and lift up.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
With a T5 screwdriver, unscrew the four T5 sized screws that hold the case back cover onto the rest of the case. Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other. Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other.
  • With a T5 screwdriver, unscrew the four T5 sized screws that hold the case back cover onto the rest of the case.
  • Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other.
Agregar Comentario
Lift the motherboard away from the case of the phone, being careful not to break the wire that goes up into the hinge. Peel the motherboard off of the keypad. The two pieces are glued together and separate without much effort. The motherboard should now be completely disconnected from the phone.
  • Lift the motherboard away from the case of the phone, being careful not to break the wire that goes up into the hinge.
  • Peel the motherboard off of the keypad. The two pieces are glued together and separate without much effort.
  • The motherboard should now be completely disconnected from the phone.
Agregar Comentario
Conclusión
Carson Meena
Miembro Desde 22/10/12
16 Reputación
7 Guías creadas
Equipo
Clemson, Team 14-2, Benson Fall 2012 Miembro de Clemson, Team 14-2, Benson Fall 2012
CLEM-BENSON-F12S14G2
4 Miembros
17 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 252
