Introducción
The SIM card stores various information, including contact list and recent call data.
Partes
No se requieren partes.
Place the phone on a flat surface with the front facing down. Insert your finger under the gray plastic cover at the bottom end of the phone. Lift the cover off the phone.
  • Place the phone on a flat surface with the front facing down.
  • Insert your finger under the gray plastic cover at the bottom end of the phone.
  • Lift the cover off the phone.
Agregar Comentario
Place your thumb in the notch in the lower left corner of the battery compartment. Lift the battery up and away from the phone. Remove the battery.
  • Place your thumb in the notch in the lower left corner of the battery compartment.
  • Lift the battery up and away from the phone.
  • Remove the battery.
Agregar Comentario
Locate the metal slider that holds the SIM card in place. Push the slider away from the metal flap which contains the SIM card. The flap will pop up.
  • Locate the metal slider that holds the SIM card in place.
  • Push the slider away from the metal flap which contains the SIM card. The flap will pop up.
Agregar Comentario
Lift the metal flap to gain access to the bottom of the SIM card. Remove the SIM card by sliding it out parallel to the bottom of the flap. Remove the SIM card by sliding it out parallel to the bottom of the flap.
  • Lift the metal flap to gain access to the bottom of the SIM card.
  • Remove the SIM card by sliding it out parallel to the bottom of the flap.
Agregar Comentario
Conclusión
Garrison Stevens
Miembro Desde 22/10/12
1 Reputación
11 Guías creadas
Equipo
Clemson, Team 15-2, Benson Fall 2012 Miembro de Clemson, Team 15-2, Benson Fall 2012
CLEM-BENSON-F12S15G2
4 Miembros
16 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 558
