Open the phone so that the keypad and screen are facing up.
  • Open the phone so that the keypad and screen are facing up.
Agregar Comentario
Use the blue plastic opening tool to pry off all four of the rubber stickers from the upper inside face.
  • Use the blue plastic opening tool to pry off all four of the rubber stickers from the upper inside face.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Use the Torx T5 screw driver head to remove the four 5.4 mm screws from the upper inner face.
  • Use the Torx T5 screw driver head to remove the four 5.4 mm screws from the upper inner face.
Agregar Comentario
Once the screws and upper casing have been removed, locate where the camera attaches to the upper circuit board and detach it using a pair of tweezers.
  • Once the screws and upper casing have been removed, locate where the camera attaches to the upper circuit board and detach it using a pair of tweezers.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Will Edwards
Miembro Desde 22/10/12
61 Reputación
17 Guías creadas
Equipo
Clemson, Team 14-1, Benson Fall 2012 Miembro de Clemson, Team 14-1, Benson Fall 2012
CLEM-BENSON-F12S14G1
4 Miembros
23 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 322
