Introducción
How to replace the screen in the Motorola V710 phone
Partes
No se requieren partes.
Insert the spudger between the gray and black plates of the screen casing. Using a twist and pry motion work your way around the phone slowly prying the two plates apart. Note: this part of the phone is glued and will require re-gluing to return the phone to its original state.
  • Insert the spudger between the gray and black plates of the screen casing.
  • Using a twist and pry motion work your way around the phone slowly prying the two plates apart.
  • Note: this part of the phone is glued and will require re-gluing to return the phone to its original state.
Agregar Comentario
If you look at the side of the now exposed screen there should be a metal casing held onto the phone by two tabs. Insert the spudger underneath one of the corners of the metal and bend it out enough to slip it over the tabs.
  • If you look at the side of the now exposed screen there should be a metal casing held onto the phone by two tabs.
  • Insert the spudger underneath one of the corners of the metal and bend it out enough to slip it over the tabs.
  • This metal is reasonably resistant to bending and will likely require a good deal of force to get it off the phone.
Agregar Comentario
Guía de regalos para el día del padre
Honremos a más que nuestros padres—celebremos a todos los mentores que nos enseñaron a reparar.
Honremos a aquellos que nos enseñaron a reparar.
Orient the phone so that the main screen is facing upward. Locate the hinge casing, a dark gray piece that covers the hinge.
  • Orient the phone so that the main screen is facing upward.
  • Locate the hinge casing, a dark gray piece that covers the hinge.
  • Insert the spudger under one of the top corners of this piece and using a twist and pry motion remove from the phone.
Agregar Comentario
Use the spudger to pry upward and remove the plug that connects the screen to the main body of the phone. Use the spudger to pry upward and remove the plug that connects the screen to the main body of the phone.
  • Use the spudger to pry upward and remove the plug that connects the screen to the main body of the phone.
Agregar Comentario
Insert the spudger under the screen and pry the screen forward. Remove the plug on the back of the screen that connects it to the camera.
  • Insert the spudger under the screen and pry the screen forward.
  • Remove the plug on the back of the screen that connects it to the camera.
Agregar Comentario
Use the spudger to remove the screen. Use the spudger to remove the screen.
  • Use the spudger to remove the screen.
Agregar Comentario
Conclusión
Michael Onnen
Miembro Desde 26/01/10
11 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 8-49, Regan Winter 2010 Miembro de Cal Poly, Team 8-49, Regan Winter 2010
CPSU-REGAN-W10S8G49
5 Miembros
16 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,969
