Introducción
This guide shows how to replace the logic board.
Remove battery cover by pushing down release lever at top of phone while prying off cover. Set cover aside. Set cover aside.
  • Remove battery cover by pushing down release lever at top of phone while prying off cover.
  • Set cover aside.
Agregar Comentario
Remove battery by grabbing it near the bottom and lifting out. Remove battery by grabbing it near the bottom and lifting out.
  • Remove battery by grabbing it near the bottom and lifting out.
Agregar Comentario
Unscrew four corner screws with T6 screwdriver. Note: The two top screws are short and silver.  The two bottom screws are black and long.
  • Unscrew four corner screws with T6 screwdriver.
    • Note: The two top screws are short and silver. The two bottom screws are black and long.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Use a spudger to gently pry off back chassis. Wedge the spudger in crevice between back panel and phone and lift. Use a spudger to gently pry off back chassis. Wedge the spudger in crevice between back panel and phone and lift. Use a spudger to gently pry off back chassis. Wedge the spudger in crevice between back panel and phone and lift.
  • Use a spudger to gently pry off back chassis. Wedge the spudger in crevice between back panel and phone and lift.
Agregar Comentario
Starting from left side of phone, remove side buttons and place aside. Note: There should be three buttons. One on each side, and the top. Return phone to starting orientation when done.
  • Starting from left side of phone, remove side buttons and place aside.
    • Note: There should be three buttons. One on each side, and the top.
  • Return phone to starting orientation when done.
Agregar Comentario
Gently remove orange ribbon cable by prying up with spudger. Gently remove orange ribbon cable by prying up with spudger. Gently remove orange ribbon cable by prying up with spudger.
  • Gently remove orange ribbon cable by prying up with spudger.
Agregar Comentario
Use a spudger to pry up logic board by wedging in between logic board and chassis and lifting. Note: Orange ribbon cable is fragile and can be broken.
  • Use a spudger to pry up logic board by wedging in between logic board and chassis and lifting.
    • Note: Orange ribbon cable is fragile and can be broken.
Agregar Comentario
Conclusión
Eric Freeman
Miembro Desde 26/01/10
1 Reputación
13 Guías creadas
Equipo
Cal Poly, Team 8-48, Regan Winter 2010 Miembro de Cal Poly, Team 8-48, Regan Winter 2010
CPSU-REGAN-W10S8G48
4 Miembros
13 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 2
Todo El Tiempo: 1,745
