Introducción
How to replace the keypad and keypad logic board.
Partes
No se requieren partes.
Depress the silver button. Pull from top of phone to lift the cover.
  • Depress the silver button.
  • Pull from top of phone to lift the cover.
A spudger may be helpful
Nick - Contestar
Hold battery from both sides at the bottom. Push upwards and gently lift to remove.
  • Hold battery from both sides at the bottom.
  • Push upwards and gently lift to remove.
Agregar Comentario
Remove 4 screws from corners using T-6 screwdriver.
  • Remove 4 screws from corners using T-6 screwdriver.
  • NOTE: Bottom two screws are gold.
  • NOTE: Make sure screws return to correct place when reassembling.
Agregar Comentario
Use plastic opening tool to pry up back cover from two side clips. NOTE: Sticker might be attached to rest of phone.
  • Use plastic opening tool to pry up back cover from two side clips.
  • NOTE: Sticker might be attached to rest of phone.
Agregar Comentario
Remove the back cover.
  • Remove the back cover.
Agregar Comentario
Use a plastic opening tool to gently remove the orange ribbon cable. Lift up the main logic board.
  • Use a plastic opening tool to gently remove the orange ribbon cable.
  • Lift up the main logic board.
  • NOTE: Rubber side buttons are not secure and might detach from the main logic board during removal.
Agregar Comentario
Remove the keypad logic board. NOTE: Plastic spacer is not secured to keypad logic board and might detach during removal.
  • Remove the keypad logic board.
  • NOTE: Plastic spacer is not secured to keypad logic board and might detach during removal.
Agregar Comentario
Remove the keypad. Remove the keypad. Remove the keypad.
  • Remove the keypad.
Agregar Comentario
Conclusión
Ryan Kuroiwa
Miembro Desde 10/04/10
1 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 25-86, Amido Spring 2010 Miembro de Cal Poly, Team 25-86, Amido Spring 2010
CPSU-AMIDO-S10S25G86
5 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 2,046
