Introducción
This section will show how to separate the pieces of the main case to reveal the internal components.
Push down on the silver button while sliding the back plate down to reveal the battery. Push down on the silver button while sliding the back plate down to reveal the battery. Push down on the silver button while sliding the back plate down to reveal the battery.
  • Push down on the silver button while sliding the back plate down to reveal the battery.
Agregar Comentario
Grab the lower edge of battery at the black areas and pull upward on the edges to remove it. Grab the lower edge of battery at the black areas and pull upward on the edges to remove it.
  • Grab the lower edge of battery at the black areas and pull upward on the edges to remove it.
Agregar Comentario
Move the the metal slider towards the top of the phone until it clicks out of its original position. Slide out and remove the SIM card. Slide out and remove the SIM card.
  • Move the the metal slider towards the top of the phone until it clicks out of its original position.
  • Slide out and remove the SIM card.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Grip the antenna and twist it counterclockwise to loosen it. When it has been loosened all the way, pull gently to remove the antenna piece.
  • Grip the antenna and twist it counterclockwise to loosen it.
  • When it has been loosened all the way, pull gently to remove the antenna piece.
Step 4 — To remove the Antenna ¶
1) Loosen it.
a) Grip the antenna
b)Twist it counterclockwise tilll it loosens completely.
2)Pull the antenna gently.
Divya - Contestar
Remove the screw covers over the two top screws by prying gently with a pin. The large cover in the upper left of the back plate has no screw behind it, so should not be removed. The large cover in the upper left of the back plate has no screw behind it, so should not be removed.
  • Remove the screw covers over the two top screws by prying gently with a pin.
  • The large cover in the upper left of the back plate has no screw behind it, so should not be removed.
Agregar Comentario
Remove all four 6.0 mm Torx screws. Remove all four 6.0 mm Torx screws. Remove all four 6.0 mm Torx screws.
  • Remove all four 6.0 mm Torx screws.
Agregar Comentario
Insert a spudger into marked holes, one at a time, and pry away from the phone to release internal tabs. Separate and detach the rear casing. Separate and detach the rear casing.
  • Insert a spudger into marked holes, one at a time, and pry away from the phone to release internal tabs.
  • Separate and detach the rear casing.
Agregar Comentario
Conclusión
Alex Georges
Miembro Desde 02/10/10
25 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 7-50, Amido Fall 2010 Miembro de Cal Poly, Team 7-50, Amido Fall 2010
CPSU-AMIDO-F10S7G50
4 Miembros
24 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,278
