Saltar al contenido principal
Motorola V551 Earpiece Speaker Replacement
Qué necesitas
  1. Motorola V551 Earpiece Speaker Replacement, Screen: paso 1, imagen 1 de 3 Motorola V551 Earpiece Speaker Replacement, Screen: paso 1, imagen 2 de 3 Motorola V551 Earpiece Speaker Replacement, Screen: paso 1, imagen 3 de 3
    Herramienta utilizada en este paso:
    Spudger
    $3.99
    Comprar
    • On the phone's face, remove the four rubber caps from the screw covers using a spudger.
  2. Motorola V551 Earpiece Speaker Replacement: paso 2, imagen 1 de 1
    • Unscrew the four cover screws using a T6 Torx screwdriver, turning counterclockwise.
  3. Motorola V551 Earpiece Speaker Replacement: paso 3, imagen 1 de 2 Motorola V551 Earpiece Speaker Replacement: paso 3, imagen 2 de 2
    • Loosen and remove the protective cover using a plastic opening tool.
  4. Motorola V551 Earpiece Speaker Replacement: paso 4, imagen 1 de 2 Motorola V551 Earpiece Speaker Replacement: paso 4, imagen 2 de 2
    • Gently loosen the second protective cover with the plastic opening tool.
  5. Motorola V551 Earpiece Speaker Replacement: paso 5, imagen 1 de 3 Motorola V551 Earpiece Speaker Replacement: paso 5, imagen 2 de 3 Motorola V551 Earpiece Speaker Replacement: paso 5, imagen 3 de 3
    • Carefully remove the protective cover from the circuitry.
    • Slowly peel the black rubber gasket off of the circuit board.
    • Carefully move the camera out of the way using your hand.
    • Use a flat tool to disconnect the upper and lower circuit boards.
  6. Motorola V551 Earpiece Speaker Replacement: paso 6, imagen 1 de 3 Motorola V551 Earpiece Speaker Replacement: paso 6, imagen 2 de 3 Motorola V551 Earpiece Speaker Replacement: paso 6, imagen 3 de 3
    • Gently slip the copper strip out from under the circuitry by using your hand.
  7. Motorola V551 Earpiece Speaker Replacement, Earpiece Speaker: paso 7, imagen 1 de 3 Motorola V551 Earpiece Speaker Replacement, Earpiece Speaker: paso 7, imagen 2 de 3 Motorola V551 Earpiece Speaker Replacement, Earpiece Speaker: paso 7, imagen 3 de 3
    • Pry out the speaker using your fingers.
Conclusión
gregatron
Miembro Desde 10/29/09
105 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 6-6, Maness Fall 2009 Miembro de Cal Poly, Team 6-6, Maness Fall 2009
CPSU-MANESS-F09S6G6
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 2,716
