Saltar al contenido principal
Motorola V551 Circuit Board Replacement
Qué necesitas
  1. Motorola V551 Circuit Board Replacement, Battery: paso 1, imagen 1 de 2 Motorola V551 Circuit Board Replacement, Battery: paso 1, imagen 2 de 2
    • Press down on the chrome button on the bottom of the chassis. Simultaneously slide the back cover down, away from the phone.
  2. Motorola V551 Circuit Board Replacement: paso 2, imagen 1 de 1
    • Lever the battery out by pressing upwards on the bottom corners of the battery.
  3. Motorola V551 Circuit Board Replacement, Circuit Board: paso 3, imagen 1 de 3 Motorola V551 Circuit Board Replacement, Circuit Board: paso 3, imagen 2 de 3 Motorola V551 Circuit Board Replacement, Circuit Board: paso 3, imagen 3 de 3
    • Remove the rubber screw covers using a plastic spudger.
    • Use a T6 Torx screwdriver to remove the screws underneath the rubber screw covers.
  4. Motorola V551 Circuit Board Replacement: paso 4, imagen 1 de 1
    • Unscrew the antenna.
  5. Motorola V551 Circuit Board Replacement: paso 5, imagen 1 de 3 Motorola V551 Circuit Board Replacement: paso 5, imagen 2 de 3 Motorola V551 Circuit Board Replacement: paso 5, imagen 3 de 3
    • Gently release the two latches using an opening tool.
    • The plastic latches are very fragile. Don’t use excessive force or they might break.
    • Pry off the back panel by wedging an opening tool into the crevice between the back panel and the circuit board.
    • Lift the back panel off of the phone.
  6. Motorola V551 Circuit Board Replacement: paso 6, imagen 1 de 2 Motorola V551 Circuit Board Replacement: paso 6, imagen 2 de 2
    • Loosen the copper circuit board connection with an opening tool.
    • Gently lift the copper connection.
  7. Motorola V551 Circuit Board Replacement: paso 7, imagen 1 de 3 Motorola V551 Circuit Board Replacement: paso 7, imagen 2 de 3 Motorola V551 Circuit Board Replacement: paso 7, imagen 3 de 3
    • Lift up and pull out the pressure pad from under the buttons on the side of the chassis.
    • Gently lift the motherboard off of the front panel.
Conclusión
3 personas más completaron esta guía.
gregatron
Miembro Desde 10/29/09
105 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 6-6, Maness Fall 2009 Miembro de Cal Poly, Team 6-6, Maness Fall 2009
CPSU-MANESS-F09S6G6
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 3,141
