Introducción
The rear panel must be removed in order to access the main inner components of the phone.
Flip the phone over so that the back is visible.
  • Flip the phone over so that the back is visible.
  • Push down on the silver button using your fingernail or thumbnail. Push down all the way until the button stops.
Agregar Comentario
While holding down the silver button, simultaneously pull downward on the rear cover, then lift it off to reveal the battery. This will only take a moment to do. This will only take a moment to do.
  • While holding down the silver button, simultaneously pull downward on the rear cover, then lift it off to reveal the battery.
  • This will only take a moment to do.
Agregar Comentario
Using your thumbnail and fingernail, grip the battery where indicated as "pull here" and lift the battery upward, starting at that side. Remove the battery completely by lifting it straight out of the phone. Remove the battery completely by lifting it straight out of the phone.
  • Using your thumbnail and fingernail, grip the battery where indicated as "pull here" and lift the battery upward, starting at that side.
  • Remove the battery completely by lifting it straight out of the phone.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
When replacing the battery, ensure that the side that has the "pull here" arrows goes toward the bottom of the phone. Place the side of the battery with the metallic contacts in toward the inside of the phone, making a full connection with the contacts within the phone (shown in the red rectangle).
  • When replacing the battery, ensure that the side that has the "pull here" arrows goes toward the bottom of the phone. Place the side of the battery with the metallic contacts in toward the inside of the phone, making a full connection with the contacts within the phone (shown in the red rectangle).
Agregar Comentario
Using a small flat head screwdriver or your fingernail, remove the rubber covers near the top of the phone Using a small flat head screwdriver or your fingernail, remove the rubber covers near the top of the phone Using a small flat head screwdriver or your fingernail, remove the rubber covers near the top of the phone
  • Using a small flat head screwdriver or your fingernail, remove the rubber covers near the top of the phone
Agregar Comentario
There are four Torx screws located on the four corners of the rear panel Remove all four screws using the T6 Torx Screwdriver. Remove all four screws using the T6 Torx Screwdriver.
  • There are four Torx screws located on the four corners of the rear panel
  • Remove all four screws using the T6 Torx Screwdriver.
Agregar Comentario
Unscrew the antenna. Remove the antenna protective tubing Remove the antenna protective tubing
  • Unscrew the antenna.
  • Remove the antenna protective tubing
Agregar Comentario
There are four light gray tabs located around the phone (two on each side) Using your finger nail or a flat head screwdriver, pull the gray tab away from the body while simultaneously lifting upward on the black rear panel. Once all four tabs are removed, lift up the back panel to reveal the interior logic board.
  • There are four light gray tabs located around the phone (two on each side)
  • Using your finger nail or a flat head screwdriver, pull the gray tab away from the body while simultaneously lifting upward on the black rear panel.
  • Once all four tabs are removed, lift up the back panel to reveal the interior logic board.
Agregar Comentario
Linea de Meta
Adrian Doan
Miembro Desde 19/01/10
22 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 4-15, Forte Winter 2010 Miembro de Cal Poly, Team 4-15, Forte Winter 2010
CPSU-FORTE-W10S4G15
5 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,905
