Saltar al contenido principal
Motorola V276 Small LCD Display Screen Replacement
Qué necesitas
  1. Motorola V276 Small LCD Display Screen Replacement, Front panel/ Screen Logic Board: paso 1, imagen 1 de 1
    • Using the plastic opening tool, pry off the top faceplate.
    • Place the tool in the small crack that runs along the side of the phone and pry.
  2. Motorola V276 Small LCD Display Screen Replacement: paso 2, imagen 1 de 1
    • Using the T6 Torx Screwdriver remove all 4 small screws.
  3. Motorola V276 Small LCD Display Screen Replacement: paso 3, imagen 1 de 1
    • Remove silver plate from phone.
  4. Motorola V276 Small LCD Display Screen Replacement: paso 4, imagen 1 de 1
    • Using the spudger remove the plastic camera casing
  5. Motorola V276 Small LCD Display Screen Replacement: paso 5, imagen 1 de 1
    • Using the iPod Opening Tool remove the yellow flex cable from the green logic board.
  6. Motorola V276 Small LCD Display Screen Replacement: paso 6, imagen 1 de 1
    • Use Spudger or hands to detach flex cable from front screen logic board
  7. Motorola V276 Small LCD Display Screen Replacement, Small LCD Display Screen: paso 7, imagen 1 de 1
    • Use a plastic opening tool to lift the small black flap to unlock the screen from the motherboard.
  8. Motorola V276 Small LCD Display Screen Replacement: paso 8, imagen 1 de 1
    • Using your fingers, carefully pull out the small LCD display screen.
  9. Motorola V276 Small LCD Display Screen Replacement: paso 9, imagen 1 de 1
    • Remove the small LCD display screen completely from the green logic board.
Conclusión
Cecilia
Miembro Desde 04/11/10
1 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 27-96, Amido Spring 2010 Miembro de Cal Poly, Team 27-96, Amido Spring 2010
CPSU-AMIDO-S10S27G96
4 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 2,729
