Introducción
Replacing the phone's headphone jack.
Partes
No se requieren partes.
Locate the silver button on the back of the phone, near the bottom.
  • Locate the silver button on the back of the phone, near the bottom.
  • Press down the button with one hand whilst sliding the back cover of the phone away from the antenna.
  • The back cover should slide off easily.
Agregar Comentario
Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
  • Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
  • With a firm grip, gently lift the end of your tool up. The battery should easily raise out of its place.
  • Now that the battery is exposed, use your fingers to remove the it from the phone.
Agregar Comentario
Note the metal connections on the phone, which are now exposed with the battery removed. There are corresponding metal connectors on the replacement battery.
  • Note the metal connections on the phone, which are now exposed with the battery removed.
  • There are corresponding metal connectors on the replacement battery.
  • When you install the battery, be sure both connectors are matched up. Otherwise, your battery will be unable to supply power to your phone.
Agregar Comentario
Guía de regalos para el día del padre
Honremos a más que nuestros padres—celebremos a todos los mentores que nos enseñaron a reparar.
Honremos a aquellos que nos enseñaron a reparar.
Use Spudger to remove rubber plug from upper left corner of the back of the phone
  • Use Spudger to remove rubber plug from upper left corner of the back of the phone
Agregar Comentario
Using a Hex T6 screwdriver, remove the 4 screws holding the back plate of the phone in place
  • Using a Hex T6 screwdriver, remove the 4 screws holding the back plate of the phone in place
Agregar Comentario
Using your hands, pull up on the back plate while pulling on the 3 side tabs to remove the back plate. Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap
  • Using your hands, pull up on the back plate while pulling on the 3 side tabs to remove the back plate.
  • Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap
Agregar Comentario
On the back casing, using a spudger, push into the headphone jack at an upward angle to pop it out
  • On the back casing, using a spudger, push into the headphone jack at an upward angle to pop it out
Agregar Comentario
Conclusión
Jason Kilroy
Miembro Desde 11/04/10
1 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 27-96, Amido Spring 2010 Miembro de Cal Poly, Team 27-96, Amido Spring 2010
CPSU-AMIDO-S10S27G96
4 Miembros
15 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 811
