Introducción
How to replace the keypad.
Partes
No se requieren partes.
Flip over the phone, press down the button and slide off the back cover. Remove the battery. Remove the battery.
  • Flip over the phone, press down the button and slide off the back cover.
  • Remove the battery.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Locate the four screws on the back of the phone. Using your T6 Torx Screwdriver, unscrew these screws. Remove the SIM card located on the back of the phone.
  • Locate the four screws on the back of the phone.
  • Using your T6 Torx Screwdriver, unscrew these screws.
  • Remove the SIM card located on the back of the phone.
  • A ribbon near the antenna is still attached to the motherboard. Do not break this ribbon.
Agregar Comentario
Conclusión
Tyler Knisley
Miembro Desde 07/05/10
1 Reputación
14 Guías creadas
Equipo
Cal Poly, Team 6-16, Maness Spring 2010 Miembro de Cal Poly, Team 6-16, Maness Spring 2010
CPSU-MANESS-S10S6G16
4 Miembros
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,446
