Introducción
Has your keypad stopped responding due to debris build-up? This guide will show you how to remove the keypad.
At the base of the antenna, use your fingers to unscrew the stem counterclockwise.
  • At the base of the antenna, use your fingers to unscrew the stem counterclockwise.
  • The antenna will pull out with little effort.
Agregar Comentario
On the back of the phone, locate the tab with the down arrow.
  • On the back of the phone, locate the tab with the down arrow.
  • Using your finger, press the tab and slide the back cover down to release it from the phone.
Agregar Comentario
Inserting your finger in the recess at the top edge of the battery, pull the battery away from the housing to remove it.
  • Inserting your finger in the recess at the top edge of the battery, pull the battery away from the housing to remove it.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Locate the three screws that secure the back battery housing to the phone.
  • Locate the three screws that secure the back battery housing to the phone.
  • Use a Torx T6 screwdriver to unscrew the screws and then remove them with your fingers.
Agregar Comentario
Using a spudger (not shown), separate by gently prying  the front from the back of the phone housing. Remove the back.
  • Using a spudger (not shown), separate by gently prying the front from the back of the phone housing.
  • Remove the back.
Agregar Comentario
The fragile wire strip connecting the display housing to the circuit board is located on the right corner of the inner hinge.
  • The fragile wire strip connecting the display housing to the circuit board is located on the right corner of the inner hinge.
  • In the same direction you would flip open the phone, use your finger to gently lift the circuit board from the plastic keypad.
Agregar Comentario
While avoiding contact with the inner electronics, use the spudger to lift the plastic keypad from the phone.
  • While avoiding contact with the inner electronics, use the spudger to lift the plastic keypad from the phone.
Agregar Comentario
Using a lens cloth, wipe away any build-up on or between the keys. Wait for the keypad to dry before reassembling.
  • Using a lens cloth, wipe away any build-up on or between the keys.
  • Wait for the keypad to dry before reassembling.
Agregar Comentario
Conclusión
Amy
Miembro Desde 15/10/12
1 Reputación
4 Guías creadas
Equipo
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 194
