Introducción
This guide will show you how to remove and replace the screen for a Motorola V3c.
Partes
No se requieren partes.
Remove the four rubber pieces from all corners of the area that borders the screen.
  • Remove the four rubber pieces from all corners of the area that borders the screen.
Agregar Comentario
Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
  • Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
  • Be sure that you do not strip or damage the screws.
Agregar Comentario
Carefully pry the screen away from the phone using a plastic spudger.
  • Carefully pry the screen away from the phone using a plastic spudger.
  • Pry slowly, as too much bending will crack the screen. There are also two fragile ribbon cables that connect the screen and camera to the phone.
Agregar Comentario
Take the screen housing off of the casing. Watch for small pieces falling out of the screen during this step. Keep track of these pieces. Watch for small pieces falling out of the screen during this step. Keep track of these pieces.
  • Take the screen housing off of the casing.
  • Watch for small pieces falling out of the screen during this step. Keep track of these pieces.
Agregar Comentario
Pry screen cover off with plastic spudger. The screen cover has some adhesive holding it to the screen
  • Pry screen cover off with plastic spudger.
  • The screen cover has some adhesive holding it to the screen
Agregar Comentario
Remove small black sticker covering the camera ribbon connector.
  • Remove small black sticker covering the camera ribbon connector.
Agregar Comentario
Flip over small hinge that covers the camera ribbon connection.
  • Flip over small hinge that covers the camera ribbon connection.
Agregar Comentario
Pull off the rubber camera cover and camera. The camera and camera cover may come off either separately or together. The camera and camera cover may come off either separately or together.
  • Pull off the rubber camera cover and camera.
  • The camera and camera cover may come off either separately or together.
Agregar Comentario
Disconnect the metallic ribbon cover.
  • Disconnect the metallic ribbon cover.
Agregar Comentario
Remove and replace the screen. Remove and replace the screen.
  • Remove and replace the screen.
Agregar Comentario
Linea de Meta
Una persona más ha completado esta guía.
Joshua Ruehlig
Miembro Desde 14/01/10
503 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 11-4, Forte Winter 2010 Miembro de Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 Miembros
8 Guías creadas
Is it a T5 or a T4 for removing the screws?
Francis Reyes - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 5
Todo El Tiempo: 8,924
