Introducción
The purpose of this guide is to show how to install or replace a Motorola V3c battery.
Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c. Lift and remove the rear panel away from the V3c. Lift and remove the rear panel away from the V3c.
  • Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
  • Lift and remove the rear panel away from the V3c.
With the phone closed, press the silver button shown with a fingernail or such. Tilt and lift the battery cover and put aside.
walltoall - Contestar
Remove the battery by pushing in the top of the battery and lifting it away from the phone. Remove the battery by pushing in the top of the battery and lifting it away from the phone.
  • Remove the battery by pushing in the top of the battery and lifting it away from the phone.
The Motorola V3 battery has a notch in one corner to ensure it can only go in one way. Fit the replacement battery by offering its bottom edge to the device, then tilt and click using thumb pressure.
Conclusión
4 personas más completaron esta guía.
krisko
Miembro Desde 14/01/10
95 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 11-4, Forte Winter 2010 Miembro de Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 1
Últimos 30 Días: 2
Todo El Tiempo: 5,615
