Saltar al contenido principal
Motorola Moto Z Play Motherboard Replacement
Qué necesitas
  1. Motorola Moto Z Play Motherboard Replacement, Display Assembly: paso 1, imagen 1 de 1
    • Power your phone off before you begin.
    • If possible, drain the battery before disassembly. When the battery is charged, there's increased risk of a dangerous thermal event if the battery is overheated or damaged during repairs.
    • If your display is cracked, completely cover it with packing tape to contain the glass shards and avoid injury.
  2. Motorola Moto Z Play Motherboard Replacement: paso 2, imagen 1 de 1
    • Prepare an iOpener and heat the front of the phone along its left edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the display.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Motorola Moto Z Play Motherboard Replacement: paso 3, imagen 1 de 3 Motorola Moto Z Play Motherboard Replacement: paso 3, imagen 2 de 3 Motorola Moto Z Play Motherboard Replacement: paso 3, imagen 3 de 3
    • In the following steps, you will separate the display assembly from the Moto Z Play's chassis.
    • For reference, refer to the first image, showing the back of the display assembly (right) after it has been removed from the phone (left).
    • If you plan to re-use the display assembly, pay particular attention to the side edges. When slicing through the glue in this area, you must be careful to insert your tool less than 2 mm, or your tool will come in contact with the display panel and damage it.
    • Playing cards are a safer, but much slower, prying tool. The soft paper cards are less likely to damage the display panel, which is good news if you plan to reuse it.
  4. Motorola Moto Z Play Motherboard Replacement: paso 4, imagen 1 de 3 Motorola Moto Z Play Motherboard Replacement: paso 4, imagen 2 de 3 Motorola Moto Z Play Motherboard Replacement: paso 4, imagen 3 de 3
    • Apply a suction cup to the display, near the middle of the left edge.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • If the screen is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • This may require a significant amount of force, but you only need to open a very slight gap with the suction cup to insert your tool.
    • If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
  5. Motorola Moto Z Play Motherboard Replacement: paso 5, imagen 1 de 1
    • Insert an opening pick (or playing card) into the gap you opened behind the display.
  6. Motorola Moto Z Play Motherboard Replacement: paso 6, imagen 1 de 3 Motorola Moto Z Play Motherboard Replacement: paso 6, imagen 2 de 3 Motorola Moto Z Play Motherboard Replacement: paso 6, imagen 3 de 3
    • Slide the tool all along the left edge of the phone to slice through the adhesive securing the display.
  7. Motorola Moto Z Play Motherboard Replacement: paso 7, imagen 1 de 1
    • Heat the front of the phone between the display and the lower edge to soften the adhesive underneath.
  8. Motorola Moto Z Play Motherboard Replacement: paso 8, imagen 1 de 3 Motorola Moto Z Play Motherboard Replacement: paso 8, imagen 2 de 3 Motorola Moto Z Play Motherboard Replacement: paso 8, imagen 3 de 3
    • Slice through the glue under the lower bezel, being careful not to damage the fingerprint sensor.
    • Slide or roll your tool past the lower edge of the fingerprint sensor and continue to the other side. Do not pry directly underneath the sensor.
    • If you plan to re-use the display, be careful not to slice or pry at the display panel. Refer to this image to help identify the glued areas while avoiding the display panel (highlighted in red).
  9. Motorola Moto Z Play Motherboard Replacement: paso 9, imagen 1 de 3 Motorola Moto Z Play Motherboard Replacement: paso 9, imagen 2 de 3 Motorola Moto Z Play Motherboard Replacement: paso 9, imagen 3 de 3
    • Continue separating the glue underneath the rest of the lower bezel.
  10. Motorola Moto Z Play Motherboard Replacement: paso 10, imagen 1 de 1
    • Heat the right edge of the phone to soften the adhesive securing the right edge of the display.
  11. Motorola Moto Z Play Motherboard Replacement: paso 11, imagen 1 de 2 Motorola Moto Z Play Motherboard Replacement: paso 11, imagen 2 de 2
    • Slide your tool along the right edge of the phone to separate the glue securing the display.
  12. Motorola Moto Z Play Motherboard Replacement: paso 12, imagen 1 de 1
    • Heat the front of the phone between the display and the top edge.
  13. Motorola Moto Z Play Motherboard Replacement: paso 13, imagen 1 de 3 Motorola Moto Z Play Motherboard Replacement: paso 13, imagen 2 de 3 Motorola Moto Z Play Motherboard Replacement: paso 13, imagen 3 de 3
    • Insert your tool at the top right corner of the phone, and begin to slide it underneath the top bezel to separate the glue.
    • As before, if you want to re-use the display, don't insert the tool far enough to touch the display panel.
    • When your tool just passes the left edge of the earpiece speaker, stop.
    • Slide or roll your tool over the top of the flash module for the selfie camera to avoid damaging it.
  14. Motorola Moto Z Play Motherboard Replacement: paso 14, imagen 1 de 2 Motorola Moto Z Play Motherboard Replacement: paso 14, imagen 2 de 2
    • If the display remains stuck, re-heat and slice the adhesive repeatedly as needed.
    • Lift the display from the left edge and swing it open, away from the phone.
  15. Motorola Moto Z Play Motherboard Replacement: paso 15, imagen 1 de 2 Motorola Moto Z Play Motherboard Replacement: paso 15, imagen 2 de 2
    • While holding the display open, use the point of a spudger to pry up the locking tab on the fingerprint sensor cable's ZIF connector.
  16. Motorola Moto Z Play Motherboard Replacement: paso 16, imagen 1 de 2 Motorola Moto Z Play Motherboard Replacement: paso 16, imagen 2 de 2
    • At the opposite end of the phone, use your spudger to flip open the locking tab on the display cable connector.
  17. Motorola Moto Z Play Motherboard Replacement: paso 17, imagen 1 de 2 Motorola Moto Z Play Motherboard Replacement: paso 17, imagen 2 de 2
    • Gently pull the fingerprint sensor cable to slide it out of its socket, disconnecting it from the motherboard.
  18. Motorola Moto Z Play Motherboard Replacement: paso 18, imagen 1 de 2 Motorola Moto Z Play Motherboard Replacement: paso 18, imagen 2 de 2
    • Gently pull the display cable to slide it out of its socket on the motherboard.
  19. Motorola Moto Z Play Motherboard Replacement: paso 19, imagen 1 de 1
    • Remove the display assembly.
  20. Motorola Moto Z Play Motherboard Replacement, Motherboard: paso 20, imagen 1 de 2 Motorola Moto Z Play Motherboard Replacement, Motherboard: paso 20, imagen 2 de 2
    • Remove the SIM card by firmly pressing the 0.8 SIM eject tool into the SIM card removal hole on the top left edge of the phone until the SIM slot pops out of the phone.
    • Completely remove the SIM card from the device.
  21. Motorola Moto Z Play Motherboard Replacement: paso 21, imagen 1 de 3 Motorola Moto Z Play Motherboard Replacement: paso 21, imagen 2 de 3 Motorola Moto Z Play Motherboard Replacement: paso 21, imagen 3 de 3
    • Remove the six 3mm T3 screws from the camera cover at the top of the phone.
    • Pry the camera cover up with your tools to pop the camera cover clips loose.
Conclusión
Reminder: Use 3M VHB Double Sided Tape to stick the screen back onto the phone.
10 personas más completaron esta guía.
Kaitlyn Fisher
Miembro Desde 10/01/17
2,012 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S15-G4, Livingston Fall 2017 Miembro de Cal Poly, Team S15-G4, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G4
4 Miembros
16 Guías creadas
Un comentario
hello, can the display connector on the motherboard be changed?
erc - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 25
Todo El Tiempo: 5,729
