Introducción
This guide has one prerequisite since the display needs to be removed.
Use the iOpener or a heat gun to heat up the edge of the screen. Your Moto X4 may not be water resistant after reassembly.
  • Use the iOpener or a heat gun to heat up the edge of the screen.
  • Your Moto X4 may not be water resistant after reassembly.
  • Before beginning the disassembly of your Moto X4, discharge the battery below 25%. A charged lithium-ion battery can catch fire or explode if accidentally punctured.
Agregar Comentario
Insert the spudger under the black tab by the top connector, then pry it up. Grab the cable and gently disconnect the screen from the rest of the Moto X4. Grab the cable and gently disconnect the screen from the rest of the Moto X4.
  • Insert the spudger under the black tab by the top connector, then pry it up.
  • Grab the cable and gently disconnect the screen from the rest of the Moto X4.
Agregar Comentario
Insert the spudger under the black tab by the bottom connector, then pry it up. Grab the cable and gently disconnect the screen from the rest of the Moto X4. Grab the cable and gently disconnect the screen from the rest of the Moto X4.
  • Insert the spudger under the black tab by the bottom connector, then pry it up.
Agregar Comentario
Free Shipping on all orders USD79.00 and up.
Visita Nuestra Tienda
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
Remove the nine 3mm T5 Torx screws securing the silver plate to the device. Remove the eleven 2mm T4 Torx screws securing the plate to the device. Incorrect placement of these screws during reassembly will cause permanent damage to your device's motherboard.
  • Remove the nine 3mm T5 Torx screws securing the silver plate to the device.
  • Remove the eleven 2mm T4 Torx screws securing the plate to the device.
  • Incorrect placement of these screws during reassembly will cause permanent damage to your device's motherboard.
Agregar Comentario
Use the flat end of a spudger to pry up the silver plate from both sides. Remove the plate from the device. Several clips hold the plate in place so there may be a clicking sound.
  • Use the flat end of a spudger to pry up the silver plate from both sides.
  • Remove the plate from the device.
  • Several clips hold the plate in place so there may be a clicking sound.
Agregar Comentario
Use a pair of tweezers to gently lift the  battery connector wire. Use a pair of tweezers to gently lift the  battery connector wire.
  • Use a pair of tweezers to gently lift the battery connector wire.
Agregar Comentario
Use the flat end of the spudger to gently pry the battery from all sides from its casing. The battery is secured to the motherboard with a mild adhesive. Peel slowly; be careful to not puncture or twist the battery. The battery is secured to the motherboard with a mild adhesive. Peel slowly; be careful to not puncture or twist the battery.
  • Use the flat end of the spudger to gently pry the battery from all sides from its casing.
  • The battery is secured to the motherboard with a mild adhesive. Peel slowly; be careful to not puncture or twist the battery.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Brian Buchanan
Miembro Desde 24/01/18
532 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S18-G4, Livingston Winter 2018 Miembro de Cal Poly, Team S18-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G4
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 10
Últimos 7 Días: 41
Últimos 30 Días: 152
Todo El Tiempo: 207
