Introducción
Replace the camera for your Motorola MOTO phone.
Using your finger, press down on the clip holding the back cover on Pull the back cover off.
  • Using your finger, press down on the clip holding the back cover on
  • Pull the back cover off.
Agregar Comentario
Place thumb and index finger in the spaces on either side of the battery. Pull battery out.
  • Place thumb and index finger in the spaces on either side of the battery.
  • Pull battery out.
Agregar Comentario
Use the plastic opening tool to pull peel back screen cover. Gently peel back the screen cover from the speaker slit. Using the T6 Torx-screwdriver, remove the four 4.3 mm screws from the top panel.
  • Use the plastic opening tool to pull peel back screen cover.
  • Gently peel back the screen cover from the speaker slit.
  • Using the T6 Torx-screwdriver, remove the four 4.3 mm screws from the top panel.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Using the flat end of the plastic opening tool, insert it underneath the plastic cover on the top right corner. Move the opening tool around the phone counter clockwise. Pop the plastic cover off by twisting the plastic covering tool.
  • Using the flat end of the plastic opening tool, insert it underneath the plastic cover on the top right corner.
  • Move the opening tool around the phone counter clockwise.
  • Pop the plastic cover off by twisting the plastic covering tool.
Agregar Comentario
Using a flat head screwdriver, insert it between the metal logic board casing and the top portion of the phone Move the plastic opening tool around the phone until part of the casting is popped off.
  • Using a flat head screwdriver, insert it between the metal logic board casing and the top portion of the phone
  • Move the plastic opening tool around the phone until part of the casting is popped off.
  • You will need to pop in the four plastic fasteners individually from the metal casing to remove it
  • Be careful not to rip the cable ribbons that are attached to the logic board and casing
Agregar Comentario
Use the flat end of the plastic opening tool to unclip the cable ribbon from the logic board
  • Use the flat end of the plastic opening tool to unclip the cable ribbon from the logic board
Agregar Comentario
You now have the top panel completely detached.
  • You now have the top panel completely detached.
Agregar Comentario
Using the plastic opening tool, peel back the plastic cover that is glued on top of the camera lens.
  • Using the plastic opening tool, peel back the plastic cover that is glued on top of the camera lens.
Agregar Comentario
Using the plastic opening tool, gently push the camera out from the front. Part of the foam holding the camera will rip from the adhesive.
  • Using the plastic opening tool, gently push the camera out from the front.
  • Part of the foam holding the camera will rip from the adhesive.
Agregar Comentario
Conclusión
C Miller
Miembro Desde 25/06/12
38 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 1-3, Regan SU 2012 Miembro de Cal Poly, Team 1-3, Regan SU 2012
CPSU-REGAN-SU12S1G3
2 Miembros
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 998
