Introducción
This guide will show you how to detach the batter on the Motorola KRZR. It will give you instructions on how to disassemble the back cover of the KRZR in order to access the battery.
Push down on the silver tab located at the top center of the back of the Motorola K1m cellphone. Push down on the silver tab located at the top center of the back of the Motorola K1m cellphone.
  • Push down on the silver tab located at the top center of the back of the Motorola K1m cellphone.
Agregar Comentario
Guía de regalos para el día del padre
Honremos a más que nuestros padres—celebremos a todos los mentores que nos enseñaron a reparar.
Honremos a aquellos que nos enseñaron a reparar.
While pushing down on the silver tab, slide the back cover towards the silver tab.
  • While pushing down on the silver tab, slide the back cover towards the silver tab.
  • Remove the back cover.
Agregar Comentario
Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery.
  • Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery.
  • Replace the old battery with the new battery.
  • Follow all of the steps to remove the battery in reverse order to reassemble.
Agregar Comentario
Conclusión
Equipo
Cal Poly, Team 11-1, Forte Winter 2010 Miembro de Cal Poly, Team 11-1, Forte Winter 2010
CPSU-FORTE-W10S11G1
5 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 4,784
