Introducción
If the buttons on your Motorola E815 are unresponsive or do not seem as crisp as they used to be, you may need to replace your keypad. To accomplish this, you will
  • Dissemble the phone
  • Access the keypad for repair or replacement
Locate the back cover release slide.
  • Locate the back cover release slide.
  • Use your finger to slide it down.
Agregar Comentario
Remove the back cover by pulling it away from the phone.
  • Remove the back cover by pulling it away from the phone.
Agregar Comentario
Locate the battery removal slot. Use your finger to pull the battery out from the top.
  • Locate the battery removal slot.
  • Use your finger to pull the battery out from the top.
  • Remove the battery.
Agregar Comentario
Locate the antenna port on the top of the phone.
  • Locate the antenna port on the top of the phone.
Removing Antenna Only
Zoie E - Contestar
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Grip the plastic support post and unscrew the apparatus using a counterclockwise twist. Pull the apparatus up and out of the phone.
  • Grip the plastic support post and unscrew the apparatus using a counterclockwise twist.
  • Pull the apparatus up and out of the phone.
Agregar Comentario
Locate the two screws on the backside of the phone.
  • Locate the two screws on the backside of the phone.
  • Unscrew the two screws using a T6 Screwdriver.
Agregar Comentario
Gently pull the top section of the phone upwards until you feel some resistance. Locate the brown connector that runs from the top section of the phone to the circuit board under the keypad. Using tweezers, gently pry the connector from the circuit board.
  • Gently pull the top section of the phone upwards until you feel some resistance.
  • Locate the brown connector that runs from the top section of the phone to the circuit board under the keypad.
  • Using tweezers, gently pry the connector from the circuit board.
  • Carefully detach the two sections of the phone.
Agregar Comentario
Using the blue pry tool, carefully pull the keypad frame away from the keypad. Gently remove the keypad frame from the keypad. Lift the silicone keypad cover off.
  • Using the blue pry tool, carefully pull the keypad frame away from the keypad.
  • Gently remove the keypad frame from the keypad.
  • Lift the silicone keypad cover off.
Agregar Comentario
Rotate the phone around so that you are looking at the battery cavity. Locate the screws on the bottom base of the phone.
  • Rotate the phone around so that you are looking at the battery cavity.
  • Locate the screws on the bottom base of the phone.
Agregar Comentario
Rotate the phone back to the front side. Slowly lift the bottom portion of the keypad off of the phone until you feel resistance.
  • Rotate the phone back to the front side.
  • Slowly lift the bottom portion of the keypad off of the phone until you feel resistance.
Agregar Comentario
Using tweezers, carefully detach the yellow connector strip from the circuit board by lifting up. Separate the keypad from the circuit board. Separate the keypad from the circuit board.
  • Using tweezers, carefully detach the yellow connector strip from the circuit board by lifting up.
  • Separate the keypad from the circuit board.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Zoie E
Miembro Desde 12/01/11
595 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 14-8, Forte Winter 2011 Miembro de Cal Poly, Team 14-8, Forte Winter 2011
CPSU-FORTE-W11S14G8
5 Miembros
5 Guías creadas
We should have a motherboard replacement.
Santi12008 - Contestar
We need to fullify more this content.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 1,931
