Introducción
When the E815 becomes unresponsive, removing and replacing the battery is often the first and best solution.
To replace the battery, you are going to:
  • Remove back cover
  • Remove Battery
  • Replace Battery
Locate the back cover release slide.
  • Locate the back cover release slide.
  • Use your finger to slide it down.
Agregar Comentario
Remove the back cover by pulling it away from the phone.
  • Remove the back cover by pulling it away from the phone.
Agregar Comentario
Locate the battery removal slot. Use your finger to pull the battery out from the top.
  • Locate the battery removal slot.
  • Use your finger to pull the battery out from the top.
  • Remove the battery.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Zoie E
Miembro Desde 12/01/11
595 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 14-8, Forte Winter 2011 Miembro de Cal Poly, Team 14-8, Forte Winter 2011
CPSU-FORTE-W11S14G8
5 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 8
Todo El Tiempo: 3,134
