Introducción
This guide will instruct the reader how to install a camera module in a Motorola Droid X. This is a rather invasive tutorial that requires much of the phone to be disassembled to get to the camera module, proceed with caution.
Locate the power button at the top of the phone.  Depress power button for 2 seconds until a menu appears. Locate the power button at the top of the phone.  Depress power button for 2 seconds until a menu appears.
  • Locate the power button at the top of the phone. Depress power button for 2 seconds until a menu appears.
Agregar Comentario
Once the menu appears, select the "power off" option.  Wait until the phone is completely off. Once the menu appears, select the "power off" option.  Wait until the phone is completely off.
  • Once the menu appears, select the "power off" option. Wait until the phone is completely off.
Agregar Comentario
Place thumb on the back cover, and push down towards the bottom of the device.  Once the cover releases, pull it away from the phone and set it aside. Place thumb on the back cover, and push down towards the bottom of the device.  Once the cover releases, pull it away from the phone and set it aside.
  • Place thumb on the back cover, and push down towards the bottom of the device. Once the cover releases, pull it away from the phone and set it aside.
Agregar Comentario
Find the yellow pull tab located in the upper left corner.  Pull the tab until the battery dislodges. Grab the battery by the raised edge, and remove it from the case. Find the yellow pull tab located in the upper left corner.  Pull the tab until the battery dislodges. Grab the battery by the raised edge, and remove it from the case.
  • Find the yellow pull tab located in the upper left corner. Pull the tab until the battery dislodges. Grab the battery by the raised edge, and remove it from the case.
Agregar Comentario
The battery has been successfully removed.
  • The battery has been successfully removed.
Agregar Comentario
Remove the micro SD card from its connector.
  • Remove the micro SD card from its connector.
Agregar Comentario
Locate the seam between the back case and the end cover on the top edge of the phone. Use the plastic opening tool to detach the two clips by wedging the tool into the right side of the seam and moving right to left.  Once the cover comes off set it aside Use the plastic opening tool to detach the two clips by wedging the tool into the right side of the seam and moving right to left.  Once the cover comes off set it aside
  • Locate the seam between the back case and the end cover on the top edge of the phone.
  • Use the plastic opening tool to detach the two clips by wedging the tool into the right side of the seam and moving right to left. Once the cover comes off set it aside
Agregar Comentario
Repeat step 2 on the bottom cover. Repeat step 2 on the bottom cover. Repeat step 2 on the bottom cover.
  • Repeat step 2 on the bottom cover.
Agregar Comentario
Use a T5 Torx screwdriver to remove the screws in each corner of the phone. The screws are very small so make sure not to lose them. The screws are very small so make sure not to lose them.
  • Use a T5 Torx screwdriver to remove the screws in each corner of the phone.
  • The screws are very small so make sure not to lose them.
Agregar Comentario
Flip the phone over and locate the screw on the middle of the left side. Unscrew it using the T5 Torx screwdriver and set it aside. Flip the phone over and locate the screw on the middle of the left side. Unscrew it using the T5 Torx screwdriver and set it aside.
  • Flip the phone over and locate the screw on the middle of the left side. Unscrew it using the T5 Torx screwdriver and set it aside.
Agregar Comentario
Identify the screw located in the bottom right corner of the battery case.  Remove the screw with a T5 (or in some cases T6) torx screwdriver and set it aside. Identify the screw located in the bottom right corner of the battery case.  Remove the screw with a T5 (or in some cases T6) torx screwdriver and set it aside.
  • Identify the screw located in the bottom right corner of the battery case. Remove the screw with a T5 (or in some cases T6) torx screwdriver and set it aside.
Agregar Comentario
Locate the seam along the right edge of the phone.  Use the prying tool to disconnect the two clips along the edge. Locate the seam along the right edge of the phone.  Use the prying tool to disconnect the two clips along the edge.
  • Locate the seam along the right edge of the phone. Use the prying tool to disconnect the two clips along the edge.
Agregar Comentario
Locate the two clips on the inside of the case and use the spudger tool to detach them from the case.  To detach each clip, use the sharp end to press the small, black plastic in the center of the clip. Locate the two clips on the inside of the case and use the spudger tool to detach them from the case.  To detach each clip, use the sharp end to press the small, black plastic in the center of the clip. Locate the two clips on the inside of the case and use the spudger tool to detach them from the case.  To detach each clip, use the sharp end to press the small, black plastic in the center of the clip.
  • Locate the two clips on the inside of the case and use the spudger tool to detach them from the case. To detach each clip, use the sharp end to press the small, black plastic in the center of the clip.
Agregar Comentario
After the clips are detached, remove the back case and set it aside. After the clips are detached, remove the back case and set it aside.
  • After the clips are detached, remove the back case and set it aside.
Agregar Comentario
Remove the screws along both sides of the motherboard using a T3 Torx screwdriver. On some phones this may require a #1 Phillips Screw Driver.
  • Remove the screws along both sides of the motherboard using a T3 Torx screwdriver. On some phones this may require a #1 Phillips Screw Driver.
These are T3 screws. I have taken apart about 15 of them in the past week, T4 is too big to fit. Had to use a T3 bit to remove them.
Christopher Moody - Contestar
These screws are T4 on my phone, not T3. I stripped 2 screws trying to remove them with T3. Maybe it could be either.
Jim Cooper - Contestar
On my phone all screws from Step 15 - 29 were actually #0 Phillip head.
Peter Merl - Contestar
Carefully remove the white connecting wire from the motherboard using tweezers. Use caution, this wire is delicate.
  • Carefully remove the white connecting wire from the motherboard using tweezers.
  • Use caution, this wire is delicate.
Agregar Comentario
Scrape away the electrical tape that covers the LCD and digitizer cable using the spudger tool or a fingernail. Scrape away the electrical tape that covers the LCD and digitizer cable using the spudger tool or a fingernail.
  • Scrape away the electrical tape that covers the LCD and digitizer cable using the spudger tool or a fingernail.
Agregar Comentario
Use the spudger tool to pop the Digitizer cable off of the motherboard.
  • Use the spudger tool to pop the Digitizer cable off of the motherboard.
Agregar Comentario
Carefully flip the small white connector up and away from the motherboard.
  • Carefully flip the small white connector up and away from the motherboard.
Agregar Comentario
Gently pull the flat gold cable out from the connector.
  • Gently pull the flat gold cable out from the connector.
Agregar Comentario
Carefully lift the motherboard and camera module up. Do not remove it from the phone!
  • Carefully lift the motherboard and camera module up. Do not remove it from the phone!
Agregar Comentario
Using the spudger tool, pop the black cable connector off of the motherboard.
  • Using the spudger tool, pop the black cable connector off of the motherboard.
Agregar Comentario
It is to safe remove the motherboard from the phone.
  • It is to safe remove the motherboard from the phone.
Agregar Comentario
Gently peel the camera's orange and gold connection cable from the motherboard.
  • Gently peel the camera's orange and gold connection cable from the motherboard.
Agregar Comentario
Remove the black electrical tape covering the cameras connection cable.
  • Remove the black electrical tape covering the cameras connection cable.
Agregar Comentario
Flip up the small white connector.  Then gently pull the orange cable out of the connecter.
  • Flip up the small white connector. Then gently pull the orange cable out of the connecter.
On my phone you have to flip up the black part of that connector (not the white part).
Eric - Contestar
Reconnect the camera module by pushing the black end of the flat cable on the camera module into the white connector on the motherboard.
  • Reconnect the camera module by pushing the black end of the flat cable on the camera module into the white connector on the motherboard.
Agregar Comentario
Conclusión
Sam Johnston
Miembro Desde 03/10/12
464 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 18-40, Regan Fall 2012 Miembro de Cal Poly, Team 18-40, Regan Fall 2012
CPSU-REGAN-F12S18G40
3 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 3
Todo El Tiempo: 2,003
