Saltar al contenido principal
Motorola Droid Turbo Front Facing Camera Replacement
Qué necesitas
  1. Motorola Droid Turbo Front Facing Camera Replacement, Rear Case: paso 1, imagen 1 de 1
    • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
  2. Motorola Droid Turbo Front Facing Camera Replacement: paso 2, imagen 1 de 2 Motorola Droid Turbo Front Facing Camera Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool to pry the rear case off of the rest of the device.
    • Remove the rear case.
    • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
  3. Motorola Droid Turbo Front Facing Camera Replacement, Midframe: paso 3, imagen 1 de 1
    • Remove the midframe bezel.
  4. Motorola Droid Turbo Front Facing Camera Replacement: paso 4, imagen 1 de 1
    • Remove the four Torx T5 screws securing the midframe plate.
  5. Motorola Droid Turbo Front Facing Camera Replacement: paso 5, imagen 1 de 1
    • Remove the midframe.
  6. Motorola Droid Turbo Front Facing Camera Replacement, Front Facing Camera: paso 6, imagen 1 de 2 Motorola Droid Turbo Front Facing Camera Replacement, Front Facing Camera: paso 6, imagen 2 de 2
    • Use the pointed end of a spudger to flip up the black retaining flap of the front facing camera's ZIF connector.
  7. Motorola Droid Turbo Front Facing Camera Replacement: paso 7, imagen 1 de 2 Motorola Droid Turbo Front Facing Camera Replacement: paso 7, imagen 2 de 2
    • Remove the front-facing camera.
Conclusión
Luis Arangu
Miembro Desde 01/20/16
1,127 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 15-5, Remmell Spring 2016 Miembro de USF Tampa, Team 15-5, Remmell Spring 2016
USFT-REMMELL-S16S15G5
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 1,704
