Saltar al contenido principal
Motorola Defy Display Assembly Replacement
Qué necesitas
  1. Motorola Defy Display Assembly Replacement, Display Assembly: paso 1, imagen 1 de 2 Motorola Defy Display Assembly Replacement, Display Assembly: paso 1, imagen 2 de 2
    • Remove the battery cover and the battery itself.
  2. Motorola Defy Display Assembly Replacement: paso 2, imagen 1 de 2 Motorola Defy Display Assembly Replacement: paso 2, imagen 2 de 2
    • Using a Torx T5 screwdriver, remove both screws near the camera.
  3. Motorola Defy Display Assembly Replacement: paso 3, imagen 1 de 1
    • Using the Torx T5 screwdriver, remove all 7 screws around the mobile: 3 on each side + 1 on the botton.
  4. Motorola Defy Display Assembly Replacement: paso 4, imagen 1 de 3 Motorola Defy Display Assembly Replacement: paso 4, imagen 2 de 3 Motorola Defy Display Assembly Replacement: paso 4, imagen 3 de 3
    • Using a plastic opener tool, open the device removing the back cover.
    • Remove the power button and volume button.
  5. Motorola Defy Display Assembly Replacement: paso 5, imagen 1 de 3 Motorola Defy Display Assembly Replacement: paso 5, imagen 2 de 3 Motorola Defy Display Assembly Replacement: paso 5, imagen 3 de 3
    • After opening the device, carefully, using the plastic opening tool, peel off the lcd and digitalizer conectors from the mainboard.
  6. Motorola Defy Display Assembly Replacement: paso 6, imagen 1 de 1
    • Remove the two yellow rubber protectors near the screws. The rectangular yellow rubber protector might fall off too so put it aside.
  7. Motorola Defy Display Assembly Replacement: paso 7, imagen 1 de 1
    • Separate the Frame + Digitizer, the LCD and the mainboard.
  8. Motorola Defy Display Assembly Replacement: paso 8, imagen 1 de 3 Motorola Defy Display Assembly Replacement: paso 8, imagen 2 de 3 Motorola Defy Display Assembly Replacement: paso 8, imagen 3 de 3
    • Now, using a plastic opening tool, carefully insert it between the frame and the glass and force it slowly to remove the adhesive. You may also heat it to help.
    • Now, Remove the rest of adhesive from the frame to better apply the new digitizer on it.
    • Follow this backwards to reassemble the mobile.
Conclusión
11 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 5,690
