Saltar al contenido principal
Motorola C290 Screen Replacement
Qué necesitas
  1. Motorola C290 Screen Replacement, Outside Case removal: paso 1, imagen 1 de 3 Motorola C290 Screen Replacement, Outside Case removal: paso 1, imagen 2 de 3 Motorola C290 Screen Replacement, Outside Case removal: paso 1, imagen 3 de 3
    • Flip open your Motorola C290.
    • Remove rubber stoppers located around main screen using a push pin.
    • This reveals four screws.
    • Use a Torx T6 Screwdriver to unscrew the four screws.
  2. Motorola C290 Screen Replacement, Removing the front casing: paso 2, imagen 1 de 2 Motorola C290 Screen Replacement, Removing the front casing: paso 2, imagen 2 de 2
    • Use a plastic opening tool to pry open a gap between the top cover and the face of the phone.
    • Slide the plastic opening tool along gap and pry open case.
    • Remove top cover.
  3. Motorola C290 Screen Replacement, Disconnect the motherboard: paso 3, imagen 1 de 2 Motorola C290 Screen Replacement, Disconnect the motherboard: paso 3, imagen 2 de 2
    • Unclip circuit attachments located on back of screen circuit board using a Spudger.
  4. Motorola C290 Screen Replacement, Removing the motherboard/screen: paso 4, imagen 1 de 3 Motorola C290 Screen Replacement, Removing the motherboard/screen: paso 4, imagen 2 de 3 Motorola C290 Screen Replacement, Removing the motherboard/screen: paso 4, imagen 3 de 3
    • Insert the plastic opening tool between the metal screen components and the plastic frame at the corners.
    • Firmly pry the screen components from the frame with a twisting motion
    • You will need to apply a good amount of force as you pry, twisting in a right-to-left motion.
    • Completely remove screen components from frame.
Conclusión
Equipo
Cal Poly, Team 24-28, Regan Spring 2010 Miembro de Cal Poly, Team 24-28, Regan Spring 2010
CPSU-REGAN-S10S24G28
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 1,765
