Introducción
This repair guide will show you how to remove the battery of the the Motorola C290.
Herramientas
No se requieren herramientas.
Position Motorola C290 so that the back of the phone is facing up. Apply pressure to the back cover while simultaneously sliding it downwards.
  • Position Motorola C290 so that the back of the phone is facing up.
  • Apply pressure to the back cover while simultaneously sliding it downwards.
  • Note: It may be easiest to apply pressure to the ridges at the top of the back cover.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Place your finger in the notch at the top of the battery. Gently lift and pull out battery.
  • Place your finger in the notch at the top of the battery.
  • Gently lift and pull out battery.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 24-28, Regan Spring 2010 Miembro de Cal Poly, Team 24-28, Regan Spring 2010
CPSU-REGAN-S10S24G28
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 2,055
