Saltar al contenido principal
Motorola C168 Front Panel Replacement
Qué necesitas
  1. Motorola C168 Front Panel Replacement, Battery: paso 1, imagen 1 de 2 Motorola C168 Front Panel Replacement, Battery: paso 1, imagen 2 de 2
    • Turn the phone so its back is facing you.
    • Press the release button on the back cover, while simultaneously pulling the cover down.
    • Remove the back cover.
  2. Motorola C168 Front Panel Replacement: paso 2, imagen 1 de 2 Motorola C168 Front Panel Replacement: paso 2, imagen 2 de 2
    • Pinch the sides of the bottom of the battery and pull upward.
  3. Motorola C168 Front Panel Replacement, SIM Card: paso 3, imagen 1 de 2 Motorola C168 Front Panel Replacement, SIM Card: paso 3, imagen 2 de 2
    • Press and slide the SIM card down.
    • Remove the SIM card.
  4. Motorola C168 Front Panel Replacement, Front Panel: paso 4, imagen 1 de 2 Motorola C168 Front Panel Replacement, Front Panel: paso 4, imagen 2 de 2
    • Orient the phone so its back is facing you.
    • Using a Torx T-4 screwdriver, carefully remove the 4 screws located at the corners of the phone.
    • Note: If you are using iFixit's screwdriver toolkit, look for the smallest T-screwbit.
  5. Motorola C168 Front Panel Replacement: paso 5, imagen 1 de 2 Motorola C168 Front Panel Replacement: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    Spudger
    $3.99
    Comprar
    • Lodge a spudger in between the front panel and the main frame of the phone.
    • Using a good amount of torque, pry the front panel from the phone.
Conclusión
Una persona más ha completado esta guía.
Christopher Wu
Miembro Desde 04/17/12
37 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 12-40, Regan Spring 2012 Miembro de Cal Poly, Team 12-40, Regan Spring 2012
CPSU-REGAN-S12S12G40
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,019
