Saltar al contenido principal
Motorola Atrix 4G Top Speaker Replacement
Qué necesitas
  1. Motorola Atrix 4G Top Speaker Replacement, Battery: paso 1, imagen 1 de 1
    • Pry the rear cover from the back of the phone.
  2. Motorola Atrix 4G Top Speaker Replacement: paso 2, imagen 1 de 2 Motorola Atrix 4G Top Speaker Replacement: paso 2, imagen 2 de 2
    • Insert a spudger or plastic opening tool into the small notch at the base of the battery.
    • Lift the battery out of the phone.
  3. Motorola Atrix 4G Top Speaker Replacement, Antenna: paso 3, imagen 1 de 3 Motorola Atrix 4G Top Speaker Replacement, Antenna: paso 3, imagen 2 de 3 Motorola Atrix 4G Top Speaker Replacement, Antenna: paso 3, imagen 3 de 3
    • Remove the four 5.0 mm T5 Torx screws from the corners of the phone.
    • Remove three 5.5 mm T5 Torx screws from the back of the phone.
    • Lift up the black rubber flap near the SD card slot.
    • Remove the single 5.5 mm T5 Torx screw beneath the flap.
    • Do not attempt to loosen the screws with too much force. These screws are small, and easily stripped.
  4. Motorola Atrix 4G Top Speaker Replacement: paso 4, imagen 1 de 2 Motorola Atrix 4G Top Speaker Replacement: paso 4, imagen 2 de 2
    • Remove the back case of the phone by gently lifting the tabs located on top of the phone near the lock button.
    • Use the case opener or spudger in these small areas because the plastic tabs can be easily broken.
    • Lift the tabs located on the bottom of the phone to continue removing the back cover.
  5. Motorola Atrix 4G Top Speaker Replacement: paso 5, imagen 1 de 2 Motorola Atrix 4G Top Speaker Replacement: paso 5, imagen 2 de 2
    • Slide an opening tool between the gap from the back of the case to the front.
    • After separating the sides, make sure there is a noticeable gap between the back case and the rest of the phone.
    • After detaching the tabs and sliding down the sides, there should be a noticeable gap between the front and back cases.
  6. Motorola Atrix 4G Top Speaker Replacement: paso 6, imagen 1 de 1
    • Carefully separate the back case from the rest of the phone by lifting it away from the phone.
    • Do not completely remove the case from the rest of the phone. The antenna is connected to both cases.
  7. Motorola Atrix 4G Top Speaker Replacement: paso 7, imagen 1 de 1
    • Disconnect the antenna from its housing on the motherboard by gently lifting beneath it.
  8. Motorola Atrix 4G Top Speaker Replacement: paso 8, imagen 1 de 1
    • Ease the antenna from out of its guide along the side of the phone
    • Once the antenna is detached, remove the back case and the antenna from the phone
    • The antenna is soldered to the back case. Do not pull with too much force.
  9. Motorola Atrix 4G Top Speaker Replacement, Motherboard: paso 9, imagen 1 de 2 Motorola Atrix 4G Top Speaker Replacement, Motherboard: paso 9, imagen 2 de 2
    • To remove the motherboard, first dislodge the right side of the motherboard, where the external connections are located, from the rest of the phone.
    • This can be done by placing a spudger in between the two ports on the phone, between the black plastic and motherboard, and prying out.
    • The motherboard should be able to be easily lifted upwards after dislodging it.
    • If the white rubber piece moves, replace it where it came from upon reassembly.
  10. Motorola Atrix 4G Top Speaker Replacement: paso 10, imagen 1 de 2 Motorola Atrix 4G Top Speaker Replacement: paso 10, imagen 2 de 2
    • First, several connections must be disconnected to completely separate the motherboard from the rest of the phone.
    • The connection highlighted with a red box must be pulled down instead of out.
    • Using the spudger tool, separate the two connections on the motherboard highlighted with orange circles by pulling them out.
    • The black switch on top of this connection acts as a lock. Push it forwards to unlock the connection.
  11. Motorola Atrix 4G Top Speaker Replacement: paso 11, imagen 1 de 1
    • After disconnecting the motherboard, there should be five distinct and separate parts of the phone: back cover, back case, front case, battery, and motherboard.
  12. Motorola Atrix 4G Top Speaker Replacement, Top Speaker: paso 12, imagen 1 de 1
    • In order to get to the top speaker, first remove the rubber cover located directly over the speaker.
    • The orange adhesive strip needs to be peeled off in order to remove the top speaker. This can be done using fingernails or the spudger tool.
  13. Motorola Atrix 4G Top Speaker Replacement: paso 13, imagen 1 de 1
    • Using the spudger, lift up from under the top speaker and it should slide easily out of place.
    • Be careful when removing top speaker out of its housing because it is still connected to the phone. You must undo the connection indicated with the orange circle before complete removal.
    • To undo the connector lift the black flap up - edge closest to the speaker - then the cable slides out
Conclusión
9 personas más completaron esta guía.
Derek Walker
Miembro Desde 04/19/12
297 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 9-42, Regan Spring 2012 Miembro de Cal Poly, Team 9-42, Regan Spring 2012
CPSU-REGAN-S12S9G42
6 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 5,520
