Introducción
This process involves first removing the battery, outer case, and motherboard. After, the keypad can be easily removed.
Partes
No se requieren partes.
Hold the phone and pull the back latch down towards the bottom. Remove the back panel by releasing the latch and lifting from the top.
  • Hold the phone and pull the back latch down towards the bottom.
  • Remove the back panel by releasing the latch and lifting from the top.
Agregar Comentario
Remove the battery by pushing the bottom end towards the top, then lifting up. Remove the battery by pushing the bottom end towards the top, then lifting up. Remove the battery by pushing the bottom end towards the top, then lifting up.
  • Remove the battery by pushing the bottom end towards the top, then lifting up.
Agregar Comentario
Once the battery is out, unscrew the six 7.0 mm screws with T-6 screwdriver. Once the screws are removed, simply lift the back panel off Once the screws are removed, simply lift the back panel off
  • Once the battery is out, unscrew the six 7.0 mm screws with T-6 screwdriver.
  • Once the screws are removed, simply lift the back panel off
Agregar Comentario
Remove the motherboard by lifting it up and out. Remove the motherboard by lifting it up and out. Remove the motherboard by lifting it up and out.
  • Remove the motherboard by lifting it up and out.
Agregar Comentario
Peel the keypad from the front case. The keypad may be stuck either to the logic board, below the screen, or the phone case itself. The keypad may be stuck either to the logic board, below the screen, or the phone case itself.
  • Peel the keypad from the front case.
  • The keypad may be stuck either to the logic board, below the screen, or the phone case itself.
Agregar Comentario
Conclusión
Mitchell Nesheim
Miembro Desde 15/04/12
26 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 6-21, Amido Spring 2012 Miembro de Cal Poly, Team 6-21, Amido Spring 2012
CPSU-AMIDO-S12S6G21
4 Miembros
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 488
