Introducción
This guide will teach you how to remove the Moto Z's rear-facing camera.
Position the opening tool under the lid of the screen. Slide the opening tool around the edge of the screen to loosen the adhesive.
  • Position the opening tool under the lid of the screen.
  • Slide the opening tool around the edge of the screen to loosen the adhesive.
Agregar Comentario
Lift the screen off the body  from the top.
  • Lift the screen off the body from the top.
Agregar Comentario
To disconnect the screen from the body, stick the spudger under one of the corners of the gold tab. Lift up, removing the tab from the device.
  • To disconnect the screen from the body, stick the spudger under one of the corners of the gold tab.
  • Lift up, removing the tab from the device.
Agregar Comentario
Pull the screen up to fully remove it.
  • Pull the screen up to fully remove it.
Agregar Comentario
Place the tweezers under the copper tab on the top of the device.
  • Place the tweezers under the copper tab on the top of the device.
  • Make sure you have a firm grip on the tab with the tweezers.
  • Make sure not to puncture the battery with the metal tweezers as it's a fire hazard.
Agregar Comentario
Slowly and carefully lift up on the tab until it pops out of the phone and is only connected by the black tape.
  • Slowly and carefully lift up on the tab until it pops out of the phone and is only connected by the black tape.
Agregar Comentario
Using the tweezers, firmly grab the black connecting tape closest to the lens. Gently pull to the right until the camera (lens and black tape) disconnects from the device.
  • Using the tweezers, firmly grab the black connecting tape closest to the lens.
  • Gently pull to the right until the camera (lens and black tape) disconnects from the device.
Agregar Comentario
Conclusión
Miriam Lam
Miembro Desde 24/01/18
606 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S2-G2, Livingston Winter 2018 Miembro de Cal Poly, Team S2-G2, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G2
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 5
Últimos 30 Días: 19
Todo El Tiempo: 112
