Introducción
If you're having sound issues, your speakers may be broken. Follow these steps to replace them.
Partes
No se requieren partes.
Turn the device so the screen is facing down.
  • Turn the device so the screen is facing down.
Agregar Comentario
Slide the battery lock switch next to the power slider to the unlocked position. Slide the battery lock switch next to the power slider to the unlocked position.
  • Slide the battery lock switch next to the power slider to the unlocked position.
Agregar Comentario
Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet. When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place. When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place.
  • Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet.
  • When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place.
Agregar Comentario
Unscrew hard drive panel using a Phillips head #1 screwdriver.
  • Unscrew hard drive panel using a Phillips head #1 screwdriver.
  • (Our device was not given to us with a hard drive or a hard drive panel)
Agregar Comentario
Pull clear plastic tab to detach hard drive from tablet. Pull clear plastic tab to detach hard drive from tablet. Pull clear plastic tab to detach hard drive from tablet.
  • Pull clear plastic tab to detach hard drive from tablet.
Agregar Comentario
To disconnect the three white ribbon cables on the side closest to the hard drive connector, pull the white plastic tabs. To disconnect the three white ribbon cables on the side closest to the hard drive connector, pull the white plastic tabs.
  • To disconnect the three white ribbon cables on the side closest to the hard drive connector, pull the white plastic tabs.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Pull the brown tabs to disconnect the white ribbon cable on the other side.
  • Pull the brown tabs to disconnect the white ribbon cable on the other side.
Agregar Comentario
Caution: do not pull on the wires, instead pull from the plastic connectors. To disconnect the remaining ribbon cables, pull the plastic connectors away from their connections.
  • Caution: do not pull on the wires, instead pull from the plastic connectors.
  • To disconnect the remaining ribbon cables, pull the plastic connectors away from their connections.
Agregar Comentario
With a Phillips #1 screwdriver, Unscrew the nine 10mm screws holding the case together.
  • With a Phillips #1 screwdriver, Unscrew the nine 10mm screws holding the case together.
Agregar Comentario
Using a spudger, press in the five tabs on the side where the battery was.
  • Using a spudger, press in the five tabs on the side where the battery was.
  • This should separate the two halves of the device. Carefully set the side with the display off to the side.
Agregar Comentario
Locate the Bluetooth board. Disconnect the ribbon cable by pulling on the plastic connector. Disconnect the ribbon cable by pulling on the plastic connector.
  • Locate the Bluetooth board.
  • Disconnect the ribbon cable by pulling on the plastic connector.
Agregar Comentario
Unscrew the 4mm screw holding the board onto the tablet. Lift the board out of the tablet and carefully set it aside.
  • Unscrew the 4mm screw holding the board onto the tablet.
  • Lift the board out of the tablet and carefully set it aside.
Agregar Comentario
Locate speaker connectors on tablet and unplug them by pulling on the plastic heads. Locate speaker connectors on tablet and unplug them by pulling on the plastic heads. Locate speaker connectors on tablet and unplug them by pulling on the plastic heads.
  • Locate speaker connectors on tablet and unplug them by pulling on the plastic heads.
Agregar Comentario
To remove the speaker near the network port, unscrew the two black 4mm screws securing it to the tablet and pull away. To remove the speaker near the network port, unscrew the two black 4mm screws securing it to the tablet and pull away.
  • To remove the speaker near the network port, unscrew the two black 4mm screws securing it to the tablet and pull away.
Agregar Comentario
To remove the speaker near the headphone jack, unscrew the one 4mm black screw securing it to the tablet. To remove the speaker near the headphone jack, unscrew the one 4mm black screw securing it to the tablet.
  • To remove the speaker near the headphone jack, unscrew the one 4mm black screw securing it to the tablet.
Agregar Comentario
Unstick the white masking tape and the black electrical tape holding the black and red wire down. Pull out the wire and speaker.
  • Unstick the white masking tape and the black electrical tape holding the black and red wire down.
  • Pull out the wire and speaker.
Agregar Comentario
Conclusión
David Troy
Miembro Desde 04/04/12
44 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 15-14, Forte Spring 2012 Miembro de Cal Poly, Team 15-14, Forte Spring 2012
CPSU-FORTE-S12S15G14
5 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 866
