Introducción
If your screen cracks or one of the pixels no longer functions correctly, you may need to replace the display screen. This guide will take you through the process of removing and replacing the display screen of the LE1600.
Partes
No se requieren partes.
Turn the device so the screen is facing down.
  • Turn the device so the screen is facing down.
Agregar Comentario
Slide the battery lock switch next to the power slider to the unlocked position. Slide the battery lock switch next to the power slider to the unlocked position.
  • Slide the battery lock switch next to the power slider to the unlocked position.
Agregar Comentario
Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet. When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place. When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place.
  • Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet.
  • When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place.
Agregar Comentario
Unscrew hard drive panel using a Phillips head #1 screwdriver.
  • Unscrew hard drive panel using a Phillips head #1 screwdriver.
  • (Our device was not given to us with a hard drive or a hard drive panel)
Agregar Comentario
Pull clear plastic tab to detach hard drive from tablet. Pull clear plastic tab to detach hard drive from tablet. Pull clear plastic tab to detach hard drive from tablet.
  • Pull clear plastic tab to detach hard drive from tablet.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
To disconnect the three white ribbon cables on the side closest to the hard drive connector, pull the white plastic tabs. To disconnect the three white ribbon cables on the side closest to the hard drive connector, pull the white plastic tabs.
  • To disconnect the three white ribbon cables on the side closest to the hard drive connector, pull the white plastic tabs.
Agregar Comentario
Pull the brown tabs to disconnect the white ribbon cable on the other side.
  • Pull the brown tabs to disconnect the white ribbon cable on the other side.
Agregar Comentario
Caution: do not pull on the wires, instead pull from the plastic connectors. To disconnect the remaining ribbon cables, pull the plastic connectors away from their connections.
  • Caution: do not pull on the wires, instead pull from the plastic connectors.
  • To disconnect the remaining ribbon cables, pull the plastic connectors away from their connections.
Agregar Comentario
With a Phillips #1 screwdriver, Unscrew the nine 10mm screws holding the case together.
  • With a Phillips #1 screwdriver, Unscrew the nine 10mm screws holding the case together.
Agregar Comentario
Using a spudger, press in the five tabs on the side where the battery was. This should separate the two halves of the device. Carefully set the side with the motherboard off to the side.
  • Using a spudger, press in the five tabs on the side where the battery was.
  • This should separate the two halves of the device. Carefully set the side with the motherboard off to the side.
Agregar Comentario
Unplug the three ribbon cables by pulling on the brown tabs and unplugging cable. Unplug the three ribbon cables by pulling on the brown tabs and unplugging cable.
  • Unplug the three ribbon cables by pulling on the brown tabs and unplugging cable.
Agregar Comentario
With a Phillips #1 screwdriver, unscrew the three 4mm screws holding the display bracket on the back side of the front buttons. With a Phillips #1 screwdriver, unscrew the three 4mm screws holding the display bracket on the back side of the front buttons.
  • With a Phillips #1 screwdriver, unscrew the three 4mm screws holding the display bracket on the back side of the front buttons.
Agregar Comentario
On the bracket behind the fingerprint scanner, unscrew the two 4mm screws holding it to the display with a Phillips #1 screwdriver. Fold away right bracket from display. Fold away right bracket from display.
  • On the bracket behind the fingerprint scanner, unscrew the two 4mm screws holding it to the display with a Phillips #1 screwdriver.
  • Fold away right bracket from display.
Agregar Comentario
Pull the plastic case away from the display screen. Pull the plastic case away from the display screen.
  • Pull the plastic case away from the display screen.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Jesse Graham
Miembro Desde 03/04/12
46 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 15-14, Forte Spring 2012 Miembro de Cal Poly, Team 15-14, Forte Spring 2012
CPSU-FORTE-S12S15G14
5 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 3,061
