Introducción
Before you start anything, you should always remove the battery. This guide will take you through this process.
Turn the device so the screen is facing down.
  • Turn the device so the screen is facing down.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Slide the battery lock switch next to the power slider to the unlocked position. Slide the battery lock switch next to the power slider to the unlocked position.
  • Slide the battery lock switch next to the power slider to the unlocked position.
Agregar Comentario
Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet. When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place. When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place.
  • Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet.
  • When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place.
Agregar Comentario
Conclusión
David Troy
Miembro Desde 04/04/12
44 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 15-14, Forte Spring 2012 Miembro de Cal Poly, Team 15-14, Forte Spring 2012
CPSU-FORTE-S12S15G14
5 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 6
Todo El Tiempo: 2,143
