Introducción
The LCD screen is held into the camera by the outer casing and an internal bracket. It is one component, so there isn't a way to just replace the LCD screen. Once screen is out of the bracket, wires must be removed to completely remove the LCD screen.
Partes
No se requieren partes.
Locate and remove the silver screws on each side of the camera. Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws. Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  • Locate and remove the silver screws on each side of the camera.
  • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
Agregar Comentario
Then, carefully pry apart the front and back outer casing away from the internal components. Be aware of the ribbon wire that will disconnect when the casing is detached. Be aware of the ribbon wire that will disconnect when the casing is detached.
  • Then, carefully pry apart the front and back outer casing away from the internal components.
  • Be aware of the ribbon wire that will disconnect when the casing is detached.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
The LCD screen has wires connecting it to the rest of the camera. A bracket holds the LCD in place, so there are no screws beyond this point.
  • The LCD screen has wires connecting it to the rest of the camera. A bracket holds the LCD in place, so there are no screws beyond this point.
  • The screen also has a ribbon wire connected at the bottom of the screen. (See 2nd picture)
Agregar Comentario
Detach the strip at the bottom from the LCD screen. Gently slide the spudger underneath the screen.
  • Detach the strip at the bottom from the LCD screen.
  • Gently slide the spudger underneath the screen.
  • Note: from the side or a corner is easiest.
  • Press the tip of the spudger down as far is you can, slowly prying away from the bracket.
Agregar Comentario
The screen is not detached, but is removed from its bracket. Note: Wires are still connecting the screen to the camera at the bottom corners.
  • The screen is not detached, but is removed from its bracket. Note: Wires are still connecting the screen to the camera at the bottom corners.
  • Check to make sure wires are connected, so it will receive proper power supply.
  • To remove the bracket for the LCD screen, remove these 1.5 mm (2 instances) screws using the #00 Phillips screwdriver.
Agregar Comentario
Conclusión
To install new LCD screen you will have to reconnect the wires and properly place in bracket. Make sure to reattach the ribbon wire before finishing repairs.
Una persona más ha completado esta guía.
Keith Sechrist
Miembro Desde 11/03/13
22 Reputación
2 Guías creadas
Equipo
Clemson, Team 12-4, Benson Spring 2013 Miembro de Clemson, Team 12-4, Benson Spring 2013
CLEM-BENSON-S13S12G4
3 Miembros
7 Guías creadas
Great procedure, thank you.
Do you know where I can buy the LCD replacement part?
I have a Konica Minolta Dimage X1 8.0 MP
mscir - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 6
Todo El Tiempo: 501
