Introducción
In the event that the battery needs to be replaced it is necessary to follow the steps of this guide to achieve this goal.
Locate the latch labeled BATT SD CARD on the right side of the camera. Push the latch in the direction of the arrow, and it will spring open.
  • Locate the latch labeled BATT SD CARD on the right side of the camera.
  • Push the latch in the direction of the arrow, and it will spring open.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Insert the battery into the larger slot until the gray tab (circled in red) clicks and secures the battery.
  • Insert the battery into the larger slot until the gray tab (circled in red) clicks and secures the battery.
  • To remove the battery, pull the gray tab back until the battery springs free.
Agregar Comentario
Conclusión
When the battery has been removed/inserted, push the latch down, and it will lock into place.
Una persona más ha completado esta guía.
Megan Milam
Miembro Desde 11/03/13
28 Reputación
5 Guías creadas
Equipo
Clemson, Team 12-4, Benson Spring 2013 Miembro de Clemson, Team 12-4, Benson Spring 2013
CLEM-BENSON-S13S12G4
3 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 10
Todo El Tiempo: 444
