Introducción
This guide can be used to remove and replace the LCD screen of the Zune 80GB.
Partes
No se requieren partes.
Use a metal spudger or Zune opening tool to remove the small silver plastic cap on top of the device.
  • Use a metal spudger or Zune opening tool to remove the small silver plastic cap on top of the device.
Agregar Comentario
There are two T4 screws under the cap. Remove both with a T4 screwdriver.
  • There are two T4 screws under the cap. Remove both with a T4 screwdriver.
  • Be careful removing the screws; the screw heads can break very easily.
Agregar Comentario
Using a metal spudger or Zune opening tool, remove the aluminum backing starting from the top. There are 5 clips on each side and two on the bottom. Be careful not to press the tools in too far; there are exposed cables right inside the edge of the device. Be careful not to press the tools in too far; there are exposed cables right inside the edge of the device.
  • Using a metal spudger or Zune opening tool, remove the aluminum backing starting from the top. There are 5 clips on each side and two on the bottom.
  • Be careful not to press the tools in too far; there are exposed cables right inside the edge of the device.
Agregar Comentario
Remove the silver tape from the bottom center and the top right. This allows access to the hard drive and the battery. Remove the silver tape from the bottom center and the top right. This allows access to the hard drive and the battery.
  • Remove the silver tape from the bottom center and the top right. This allows access to the hard drive and the battery.
Agregar Comentario
Unclick the black bar connecting the orange hard drive cable to the bottom of the hard drive. Gently push towards the bottom of the device on the black bar until you hear a click sound, it is now disengaged from the hard drive. If the cable doesn't come off easily, the black bar has not been un-clicked. Now gently pull the orange hard drive cable to remove it from the hard drive.
  • Unclick the black bar connecting the orange hard drive cable to the bottom of the hard drive. Gently push towards the bottom of the device on the black bar until you hear a click sound, it is now disengaged from the hard drive.
  • If the cable doesn't come off easily, the black bar has not been un-clicked.
  • Now gently pull the orange hard drive cable to remove it from the hard drive.
  • Lift the hard drive from the device.
  • Hard Drive Replacement Only: Check to make sure the hard drive cable is in good condition and then connect the new hard drive in the same place, following the steps in reverse order.
Agregar Comentario
Remove two more pieces of silver tape from the bottom of the device. One of these pieces is below the other. Remove two more pieces of silver tape from the bottom of the device. One of these pieces is below the other.
  • Remove two more pieces of silver tape from the bottom of the device. One of these pieces is below the other.
Agregar Comentario
Remove the two T4 screws holding the headphone jack receiver on the top left corner of the device.
  • Remove the two T4 screws holding the headphone jack receiver on the top left corner of the device.
Agregar Comentario
Remove the two T4 screws holding the metal brackets on both sides of the bottom of the device. Remove the screws, brackets, and clips from the device. These are small pieces, so put them in a safe place. Remove the screws, brackets, and clips from the device. These are small pieces, so put them in a safe place.
  • Remove the two T4 screws holding the metal brackets on both sides of the bottom of the device.
  • Remove the screws, brackets, and clips from the device. These are small pieces, so put them in a safe place.
Agregar Comentario
The orange audio board cable is clipped in with a small black bar, same as the hard drive cable. Un-clip the bar by pushing upwards on the edge of the black bar towards the orange cable. You will hear it click when is disengages.
  • The orange audio board cable is clipped in with a small black bar, same as the hard drive cable. Un-clip the bar by pushing upwards on the edge of the black bar towards the orange cable. You will hear it click when is disengages.
  • WARNING: If the cable doesn't come off easily, the black bar has not been un-clicked.
Agregar Comentario
Flip the black bar to unclip the left side of the hard drive cable. You can now remove the hard drive cable.
  • Flip the black bar to unclip the left side of the hard drive cable. You can now remove the hard drive cable.
Agregar Comentario
Remove the two T4 screws that hold the charging port on the bottom of the device. Remove the charging port.
  • Remove the two T4 screws that hold the charging port on the bottom of the device.
  • Remove the charging port.
Agregar Comentario
Remove the battery from the device with the cables still connected. Carefully lift up the mother board located at the base of the Zune. Unclip the orange ribbon cable in the same manner as in the previous steps. Remove the mother board from the Zune, leaving the black wire connected.
  • Remove the battery from the device with the cables still connected.
  • Carefully lift up the mother board located at the base of the Zune. Unclip the orange ribbon cable in the same manner as in the previous steps.
  • Remove the mother board from the Zune, leaving the black wire connected.
Agregar Comentario
Carefully remove the wireless assembly that runs along the top and upper left edges of the Zune. The assembly is lightly glued to the device. Use caution, as some force will be needed, but too much force will damage the board.
  • Carefully remove the wireless assembly that runs along the top and upper left edges of the Zune.
  • The assembly is lightly glued to the device. Use caution, as some force will be needed, but too much force will damage the board.
  • Remove the assembly and the battery together as a unit.
Agregar Comentario
Gently pry the screen unit from the black, plastic front frame. Screen Replacement Only:  After fixing the original screen or purchasing a new one, simply place the screen back into black frame and re-install the cables in the reverse order of this guide.
  • Gently pry the screen unit from the black, plastic front frame.
  • Screen Replacement Only: After fixing the original screen or purchasing a new one, simply place the screen back into black frame and re-install the cables in the reverse order of this guide.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
nwiswell
Miembro Desde 05/11/09
55 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 6-5, Maness Fall 2009 Miembro de Cal Poly, Team 6-5, Maness Fall 2009
CPSU-MANESS-F09S6G5
5 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 7
Todo El Tiempo: 5,374
