Introducción
The 30 GB hard drive is attached to the logic board. The battery should be removed before any more disassembling of the Zune is to take place.
Qué necesitas
Remove the plastic screw cover located on the bottom of the device. Insert a small flat-headed screwdriver into one side of the cover and gently ease it out. Repeat on the other side.
You will need a #00 Phillips screwdriver to remove the two 2.6 mm screws that are exposed.
Turn the Zune over so the screen faces downward. This will ensure the battery does not fall out and pull on the cable.
Pry up from the bottom of the Zune because the headphone jack will not allow you to remove the back case in one pull. You must slide the case up and away from the rest of the Zune.
Use the small flat head screw driver to gently lift the brown clamp.
The clamp will release the battery ribbon cable from the logic board, freeing the battery.
Now the back cover is off and the battery is removed, so the hard drive is clearly visible.
There are four 4.2 mm screws securing the hard drive to the logic board.
Remove all four screws using a Phillips #00 screwdriver.
11 personas más completaron esta guía.
