Saltar al contenido principal
Microsoft Surface 3 Battery Replacement
Qué necesitas
  1. Microsoft Surface 3 Battery Replacement, Casing: paso 1, imagen 1 de 2 Microsoft Surface 3 Battery Replacement, Casing: paso 1, imagen 2 de 2
    • Warm up an iOpener following the instructions found in the iOpener guide.
    • Place the warm iOpener on top of the edges of the screen. This heat will weaken the strength of the adhesive between the display and body.
  2. Microsoft Surface 3 Battery Replacement: paso 2, imagen 1 de 2 Microsoft Surface 3 Battery Replacement: paso 2, imagen 2 de 2
    • Use iFixit opening picks to wedge under the edge of the screen at the speaker port.
    • This may take significant force. A fingernail might work better for the initial lift
    • If you push straight down near the edge you will go through the speaker mesh and possibly end up damaging your speaker; try to push the pick in at a shallow angle.
  3. Microsoft Surface 3 Battery Replacement: paso 3, imagen 1 de 2 Microsoft Surface 3 Battery Replacement: paso 3, imagen 2 de 2
    • Carefully try to work your way around the device using the picks, reapplications of the heated iOpener, and luck.
    • If you break the glass on one side you might want to try again starting from the other side so that you have a clean, unbroken, edge on that side.
    • While the glass on this display is not particularly sharp when broken, it is still broken glass and you should be careful with it.
  4. Microsoft Surface 3 Battery Replacement: paso 4, imagen 1 de 1
    • Flip the display over so that parts underneath it are easily accessible.
    • Do not pull out the display as it is still attached to the motherboard.
    • If you are replacing the display, or want it out of the way, continue with the display replacement guide steps.
  5. Microsoft Surface 3 Battery Replacement, Battery: paso 5, imagen 1 de 1
    • Now that you've gotten the casing off of the Surface 3, you can start removing the battery pack.
  6. Microsoft Surface 3 Battery Replacement: paso 6, imagen 1 de 3 Microsoft Surface 3 Battery Replacement: paso 6, imagen 2 de 3 Microsoft Surface 3 Battery Replacement: paso 6, imagen 3 de 3
    Herramienta utilizada en este paso:
    Plastic Cards
    $2.99
    Comprar
    • Slide the iFixit plastic cards under the compartments of the battery pack.
    • Slide the card around to undo the adhesive under the battery pack
  7. Microsoft Surface 3 Battery Replacement: paso 7, imagen 1 de 3 Microsoft Surface 3 Battery Replacement: paso 7, imagen 2 de 3 Microsoft Surface 3 Battery Replacement: paso 7, imagen 3 de 3
    • Carefully slide the battery's flat power and data connector from its insert.
    • You may now switch out the battery pack for a new one.
Conclusión
21 personas más completaron esta guía.
Equipo
Cal Poly, Team 5-12, Maness Fall 2015 Miembro de Cal Poly, Team 5-12, Maness Fall 2015
CPSU-MANESS-F15S5G12
4 Miembros
18 Guías creadas
13 comentarios
I followed these instructions without a hitch but now that I'm trying to put the new battery in I can't slide the connector for the new battery back in. It seems like the teeth that are supposed to grab the connector for the battery are too tight so I can't side the director for the battery in. Do you have any advise for this issue that I'm having?
John Salazar - Contestar
Recently had to complete this repair for a customer. Was in the same boat, couldn’t figure out how to plug the battery back in. And wasn’t paying attention to how the connection was originally, when i pulled the battery. The connector has to slide UNDER the teeth, not above. Meaning loosen the board screws and lift the board slightly, then slide the battery connector in. hopefully this helps others that a stuck with this issue, and iFixit will update this guide.
Marno Junta -
Great pictures and tools shown.
philbu - Contestar
Hab’s versucht und es hat leider nicht mal in Ansätzen geklappt. Genau wie beschrieben hab ich den iOpener 30 Sekunden lang in der Mikrowelle erhitzt und dann auf die rechte Seite des Geräts gelegt. Nach ein paar Minuten war ich der Meinung es kann losgehen und hab wie beschrieben an der Einbuchtung des Lautsprechers das Glas leicht angehoben und mit dem Plektrum in flachem Winkel angesetzt. Bevor ich noch groß Kraft anwenden konnte hatte ich schon den Sprung und ein ordentliches Stück Glas ist mir weggesprungen. Zunächst dachte ich dass es halb so schlimm sei, denn es hat “nur” den schwarzen Rand erwischt, nicht jedoch das Tochscreen selbst. Naja nach kurzer Zeit ist der Riss gewandert und nachdem die Tochfunktion nicht mehr ging, kamen danach die bunten Streifen…. 300€ kostet der Displaytausch und noch mal 90€ der Akku tausch. Hätte ich gewusst wie unfassbar leicht das Glas springt, hätte ich sofort den Akkutausch machen lassen und nicht selbst Hand angelegt -.-
Elias Aminger - Contestar
Anyone know where to find a photo of the motherboard?
Frank Ho - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 14
Ultimos 7 días: 137
Ultimos 30 días: 644
Todo El Tiempo: 90,943
