Introducción
A guide showing how to disassemble and clean a Microsoft Natural Multimedia Keyboard.
A guide showing how to disassemble and clean a Microsoft Natural Multimedia Keyboard. You will need a spudger to remove the keys. An IC mounting tool can be helpful in replacing them. You will need a spudger to remove the keys. An IC mounting tool can be helpful in replacing them.
  • A guide showing how to disassemble and clean a Microsoft Natural Multimedia Keyboard.
  • You will need a spudger to remove the keys. An IC mounting tool can be helpful in replacing them.
Agregar Comentario
Use the flat end of a spudger to pop the keys off the keyboard. Use the flat end of a spudger to pop the keys off the keyboard. Use the flat end of a spudger to pop the keys off the keyboard.
  • Use the flat end of a spudger to pop the keys off the keyboard.
Agregar Comentario
Wider keys will have a retaining bar, take note of how they come off to make reassembly easier. Continue removing keys. Continue removing keys.
  • Wider keys will have a retaining bar, take note of how they come off to make reassembly easier.
  • Continue removing keys.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the 10 screws from the bottom of the keyboard. Remove the upper button assembly. Remove the upper button assembly.
  • Remove the 10 screws from the bottom of the keyboard.
  • Remove the upper button assembly.
Agregar Comentario
Use the tip of a spudger to push the upper button assembly buttons out from the back. Use the tip of a spudger to push the upper button assembly buttons out from the back. Use the tip of a spudger to push the upper button assembly buttons out from the back.
  • Use the tip of a spudger to push the upper button assembly buttons out from the back.
Agregar Comentario
Remove the flexible keypad from the key caddy assembly. The key caddies can be washed in the sink. The key caddies can be washed in the sink.
  • Remove the flexible keypad from the key caddy assembly.
  • The key caddies can be washed in the sink.
Agregar Comentario
The keys can also be washed.
  • The keys can also be washed.
  • Remove the metal retaining clips before washing to prevent rust.
Agregar Comentario
Conclusión
6 personas más completaron esta guía.
asvnix
Miembro Desde 18/11/12
220 Reputación
1 Guía escrita
Thank you so much! I had never done this before and was very confused by the retaining bar.
Des Blackoak - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 29
Últimos 30 Días: 145
Todo El Tiempo: 6,539
