Saltar al contenido principal
Magellan RoadMate 1200 GPS Sensor Replacement
Qué necesitas
  1. Magellan RoadMate 1200 GPS Sensor Replacement, Back Cover: paso 1, imagen 1 de 2 Magellan RoadMate 1200 GPS Sensor Replacement, Back Cover: paso 1, imagen 2 de 2
    • Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
  2. Magellan RoadMate 1200 GPS Sensor Replacement: paso 2, imagen 1 de 1
    • Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
  3. Magellan RoadMate 1200 GPS Sensor Replacement: paso 3, imagen 1 de 2 Magellan RoadMate 1200 GPS Sensor Replacement: paso 3, imagen 2 de 2
    • Remove the back cover from the device by separating the back cover along its seam.
    • Slowly lift the cover—the speaker is screwed onto the back cover and is connected to the circuit board.
  4. Magellan RoadMate 1200 GPS Sensor Replacement: paso 4, imagen 1 de 2 Magellan RoadMate 1200 GPS Sensor Replacement: paso 4, imagen 2 de 2
    • Pull the speaker cord, horizontally, by its base, away from the motherboard.
    • When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
  5. Magellan RoadMate 1200 GPS Sensor Replacement, Motherboard: paso 5, imagen 1 de 1
    • Remove the two screws on that are located on opposite sides of the board.
  6. Magellan RoadMate 1200 GPS Sensor Replacement: paso 6, imagen 1 de 1
    • Lift up the circuit board and disconnect the GPS wire, pulling horizontally from its connector port.
  7. Magellan RoadMate 1200 GPS Sensor Replacement, GPS Sensor: paso 7, imagen 1 de 2 Magellan RoadMate 1200 GPS Sensor Replacement, GPS Sensor: paso 7, imagen 2 de 2
    • Carefully flip the circuit board out so you can get to the sensor easily.
    • Remove the tape holding the sensor to the display and take out the sensor.
Conclusión
Una persona más ha completado esta guía.
Ross Light
Miembro Desde 04/12/10
217 Reputación
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 3,133
