Introducción
Use this as a guide to remove or replace the rubber part of the directional pad.
Use tweezers to completely remove the sticker from the rear of controller.
  • Use tweezers to completely remove the sticker from the rear of controller.
Agregar Comentario
Find the seven 8.3 mm Phillips screws on the rear of the controller and remove them.
  • Find the seven 8.3 mm Phillips screws on the rear of the controller and remove them.
Agregar Comentario
Use a plastic opening tool to separate the rear and front casing by inserting it in-between the two cases. Use the plastic opening tool to pry the two cases apart.
  • Use a plastic opening tool to separate the rear and front casing by inserting it in-between the two cases.
  • Use the plastic opening tool to pry the two cases apart.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the two rubber side grips. Remove the two rubber side grips.
  • Remove the two rubber side grips.
Agregar Comentario
Locate RS-DP-LS switch. Pull upwards on the switch to remove it.
  • Locate RS-DP-LS switch.
  • Pull upwards on the switch to remove it.
Agregar Comentario
Locate the four 8.3 mm Phillips screws on the circuit board and remove them.
  • Locate the four 8.3 mm Phillips screws on the circuit board and remove them.
Agregar Comentario
Hold the controller cable at the area just before it meets the controller and slowly lift upwards to slide it out of its plastic slot and remove the circuit board. Be careful with the wires connected to the circuit board itself as they are thin and delicate. When reassembling the controller, make sure that the bottom plastic piece is fully inserted into its slot before replacing the circuit board.
  • Hold the controller cable at the area just before it meets the controller and slowly lift upwards to slide it out of its plastic slot and remove the circuit board.
  • Be careful with the wires connected to the circuit board itself as they are thin and delicate.
  • When reassembling the controller, make sure that the bottom plastic piece is fully inserted into its slot before replacing the circuit board.
Agregar Comentario
Use tweezers to remove the rubber part of the directional pad.
  • Use tweezers to remove the rubber part of the directional pad.
Agregar Comentario
Insert a new directional pad over the original directional pad's location. Insert a new directional pad over the original directional pad's location.
  • Insert a new directional pad over the original directional pad's location.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Jefferson
Miembro Desde 26/09/12
60 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 1-7, Propen Fall 2012 Miembro de Cal Poly, Team 1-7, Propen Fall 2012
CPSU-PROPEN-F12S1G7
4 Miembros
7 Guías creadas
mi spiegate l'utilita di questa guida?vendere forse le pinzette e tutte le altre stronzatine che servono per riparare il fightpad?quando invece il pezzo più importante cioè il gommino non lo vendete....fate pena
auredo1988 - Contestar
Hi I don't speak Italian but I think you are asking "what is the purpose of this guide?". We made these as a project for university because I wanted to resolder a wire in this controller that came undone. For good measure we made a guide for each individual part although the real purpose of these guides was for the full disassembly and re soldering.
Eric Devlin - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 4
Últimos 30 Días: 22
Todo El Tiempo: 3,327
