Introducción
The trackpad is used to move the cursor on the screen. It is located below the keyboard.
Partes
No se requieren partes.
The battery compartment is located in the front-right side of the laptop.
  • The battery compartment is located in the front-right side of the laptop.
Agregar Comentario
To insert the battery, gently slide it into the compartment until it clicks in place.
  • To insert the battery, gently slide it into the compartment until it clicks in place.
  • To remove, slide the button highlighted in the red rectangle to the right to release the battery and slide it from the compartment.
This is not to remove the battery, this is to remove the expansion slot (which has got the floppy disk module in it, in the first picture.
blrutter - Contestar
Sorry I should have mentioned it in my prior comment. The battery has got a release button on it too, but it’s part of the battery, exposed on the front face of the right front corner when the battery is installed.
With the laptop upside down and with the battery removed, use a Torx #9 screw driver to remove the three .84 in. screws shown.
  • With the laptop upside down and with the battery removed, use a Torx #9 screw driver to remove the three .84 in. screws shown.
Agregar Comentario
Carefully pull up on the front of the keyboard to pop it out from the case. Then slide the back out so the keyboard becomes nearly free.
  • Carefully pull up on the front of the keyboard to pop it out from the case.
  • Then slide the back out so the keyboard becomes nearly free.
Agregar Comentario
Disconnect the ribbon that is connecting the keyboard to the rest of the computer. Pull the keyboard out and repair or replace as needed. Pull the keyboard out and repair or replace as needed.
  • Disconnect the ribbon that is connecting the keyboard to the rest of the computer.
  • Pull the keyboard out and repair or replace as needed.
Agregar Comentario
Remove the front plastic panel of the laptop by carefully lifting it up. Remove the front plastic panel of the laptop by carefully lifting it up. Remove the front plastic panel of the laptop by carefully lifting it up.
  • Remove the front plastic panel of the laptop by carefully lifting it up.
Agregar Comentario
Remove the orange stripped ribbon that connects the trackpad to the rest of the laptop by carefully pulling up.
  • Remove the orange stripped ribbon that connects the trackpad to the rest of the laptop by carefully pulling up.
I would really like to see how the ribbon goes back in under the keyboard, as my laptop had some parts fall off.
Justin T - Contestar
With a Torx #9 screwdriver, remove the two .20 in. screws circled in red that are holding the trackpad in place. Then disconnect the ribbon highlighted with the red rectangle connecting the trackpad to the laptop.
  • With a Torx #9 screwdriver, remove the two .20 in. screws circled in red that are holding the trackpad in place.
  • Then disconnect the ribbon highlighted with the red rectangle connecting the trackpad to the laptop.
Agregar Comentario
The trackpad can now be removed from the laptop.
  • The trackpad can now be removed from the laptop.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Ronan
Miembro Desde 10/10/11
42 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 6-1, Regan Fall 2011 Miembro de Cal Poly, Team 6-1, Regan Fall 2011
CPSU-REGAN-F11S6G1
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 4
Todo El Tiempo: 808
