Introducción
Use guide to replace a worn or broken track ball assembly.
Partes
No se requieren partes.
Orient the computer so the battery is facing you.
  • Orient the computer so the battery is facing you.
  • Slide the gray plastic battery cover to the right.
Agregar Comentario
Pull the battery toward yourself until it is fully detached.
  • Pull the battery toward yourself until it is fully detached.
Agregar Comentario
Orient the computer right side up with the rear facing you.
  • Orient the computer right side up with the rear facing you.
  • Open the Input/Output (I/O) door.
Agregar Comentario
Carefully bend the door into an arch until one of the pins releases from its slot.
  • Carefully bend the door into an arch until one of the pins releases from its slot.
  • Once one of the pins is free, remove the I/O door from the computer.
Agregar Comentario
Orient the computer with the bottom facing up and rear facing you. You should be able to read the Macintosh label in this position.
  • Orient the computer with the bottom facing up and rear facing you. You should be able to read the Macintosh label in this position.
Agregar Comentario
Use a T8 torx screwdriver to remove the 6.8mm long screw above and to the right of the modem jack.
  • Use a T8 torx screwdriver to remove the 6.8mm long screw above and to the right of the modem jack.
  • Twist counter clockwise to remove the screw.
Agregar Comentario
Use a T10 torx screwdriver to remove the four, 18mm long screws from the lower case.
  • Use a T10 torx screwdriver to remove the four, 18mm long screws from the lower case.
Agregar Comentario
Place your hands on the lower case, just above the I/O panel, and slowly lift the lower case a few inches above the main body of the computer. Release the large, gray interconnect ribbon cable just behind the I/O panel.
  • Place your hands on the lower case, just above the I/O panel, and slowly lift the lower case a few inches above the main body of the computer.
  • Release the large, gray interconnect ribbon cable just behind the I/O panel.
  • Caution: Lower case cannot be fully removed until two plastic clips in the front corners are released. See the following step for details.
Agregar Comentario
Place your thumb on the upper case, inside the empty battery slot, and your index finger near your thumb on the left side of the lower case. Pinch your thumb and index finger towards each other to release the clip. Without releasing pressure on the pinch grip, use your index finger to push the lower case upwards.
  • Place your thumb on the upper case, inside the empty battery slot, and your index finger near your thumb on the left side of the lower case.
  • Pinch your thumb and index finger towards each other to release the clip. Without releasing pressure on the pinch grip, use your index finger to push the lower case upwards.
  • Lift the lower case to remove it.
Agregar Comentario
Locate the trackball assembly.  It is in the upper case and can be identified by a green circuit board. Open the white tab fastener by pulling out on each side.   and remove the green and silver ribbon cable.
  • Locate the trackball assembly. It is in the upper case and can be identified by a green circuit board.
  • Open the white tab fastener by pulling out on each side. and remove the green and silver ribbon cable.
  • Remove the green and silver ribbon cable by gently pulling it away from the opened tab fastener.
Agregar Comentario
Use a T8 torx screwdriver to remove the six, 6.8mm long screws from the top of the green circuit board.
  • Use a T8 torx screwdriver to remove the six, 6.8mm long screws from the top of the green circuit board.
Agregar Comentario
Remove all four components of the trackball assembly by lifting upward.
  • Remove all four components of the trackball assembly by lifting upward.
  • The four components of the trackball assembly should include: the green circuit board, a metal support, the track ball, and the casing.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
John
Miembro Desde 12/10/11
70 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 6-3, Regan Fall 2011 Miembro de Cal Poly, Team 6-3, Regan Fall 2011
CPSU-REGAN-F11S6G3
4 Miembros
12 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 11
Últimos 30 Días: 18
Todo El Tiempo: 855
