Introducción
Use this guide to replace or remove the Input/Output door.
Orient the computer right side up with the rear facing you.
  • Orient the computer right side up with the rear facing you.
  • Open the Input/Output (I/O) door.
Agregar Comentario
Carefully bend the door into an arch until one of the pins releases from its slot.
  • Carefully bend the door into an arch until one of the pins releases from its slot.
  • Once one of the pins is free, remove the I/O door from the computer.
Agregar Comentario
Conclusión
Jason
Miembro Desde 12/10/11
64 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 6-3, Regan Fall 2011 Miembro de Cal Poly, Team 6-3, Regan Fall 2011
CPSU-REGAN-F11S6G3
4 Miembros
12 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 671
