Introducción
No sound from the right side of your MacBook Pro? Use this guide to replace the subwoofer and right speaker assembly.
Remove the following ten screws securing the lower case to the upper case:
    • Seven 3 mm Phillips screws.
important to reassemble the "lower case" successfully: the threads of the seven 3mm phillips screws are drilled at an angle :-/
mysterioes - Contestar
Same issue with me. After reassembling my 13-inch and my 17-inch, one of the screws are sticking out ever so slightly. Very annoying, especially since I scratch whatever surface I'm on now.
Kyle Spadaro -
Very important note; this guide is NOT correct for the Macbook Pro 17" A1297 late '11.
The A1297 has an assembly adjacent to the optical drive, identifiable by 4 antenna connectors, 1 usb cable (with very small connector) and one PCI-e flat cable running across the optical drive.
I did not take pictures, but found one on the web. I'm very new to iFixit and have no idea yet on how to create a guide, but here's the picture showing the assembly on top (this pic only has 3 antenna wires, the A1297 has 4, but at least you'll know what to look for.
- carefully undo all connections and 2 screws
- remove the assembly and flip it over
- again carefully remove the shielding tape
- undo 3 tiny screws
- gently pry the airport card from the assembly (the flat cable will be a bit of a pain)
- reverse process with replacement card.
image can be found here:
https://dl.dropboxusercontent.com/u/2446...
Remon - Contestar
It helps if you mark the holes where the long screws go so you can easily find them when the time comes to button things up. Also, a little dish or custard cup to hold those tiny screws is essential.
Human - Contestar
3 x 13.5 mm screws are actually TWO different types! Return to EXACT SAME HOLES.
-I discovered this on my mid-2010, but from comments, sounds like it may affect other models as well
2 x 13.5 mm screws are pointed ends
1 x 13.5 mm screw is a FLAT end <- CORNER HOLE
These areTWO slightly different lengths, and must return to correct holes. If you put the flat end screw in the wrong hole, it will stick out slightly. If you put either of the pointed screws in the wrong hole, they will go in all the way, but will not catch threads, and will simply fall out when laptop is flipped back over.
scottbernardis - Contestar
I printed out the image above and taped each screw to the photo as I removed each one, just to make sure I put them in the right location.
Grace Morris - Contestar
This is a brilliant suggestion! I did this for all the steps that involved removing screws, numbered the sheets, and that made it very easy to put it all back together in reverse. Thanks!
Steve Adamczyk -
Wedge your fingers between the lower case and the vent, and lift upward to release the clips holding the lower case to the upper case. Remove the lower case.
  • Wedge your fingers between the lower case and the vent, and lift upward to release the clips holding the lower case to the upper case.
  • Remove the lower case.
I recommend using anti-static protection, i.e., wearing a ground strap, or at least touch metal chassis inside the computer before unplugging cables. Otherwise, you might create an ESD discharge into your RAM and have to replace it like I did!
d68ef792 - Contestar
Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits. If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device.  For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up. If the plastic tab is missing, use a spudger to pry the connector up from its socket.
  • Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits.
  • If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
  • If the plastic tab is missing, use a spudger to pry the connector up from its socket.
  • Pull the tab parallel to the face of the logic board.
This step is a little difficult in reverse, that is, when re-attaching the battery. It helps to tilt the laptop up so you can see the edge of the board that accepts the plug. It may look like there are two slots for it, it goes in the bigger slot that is further away from the board.
yary hluchan - Contestar
Is this step really necessary? It is not part of the instructions how to replace the HDD in Apple's User Manual of the 2011 17" MBP.
Tobias Hahn - Contestar
As it says in the step: "Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits." It is not required, but it is simple insurance to avoid a $1000+ repair should you accidentally short components on the board with something metal.
Andrew Bookholt -
There was no tab on my model. Battery is affixed to board and screws must be removed.
bhodges2 - Contestar
Mine also, and looks as if removing connector could damage motherboard.
Stephen -
* There is no tab on the A1297 (late 2011) model's battery connector. Be careful with the connector, it chips off the edges easily! Otherwise the same as bhodges2 & Stephen's notes.
** (Pleas also include the exact Model and Part numbers like P/N: MD311D/A; Mod.: A1297 in the comments and notes for your MBP)
Pinguman - Contestar
Why are there no guides for the Late 2011 17" MacBook Pro A1297 (2.4GHz i7 quad core, MD311LL/A)??? I just replaced the RAM in mine and discovered that not only is there no tab on the battery connector, but the connector pulls straight up, perpendicular to the logic board, rather than parallel. I almost ripped the wires out of the connector by trying to pull it out parallel to the logic board like this guide instructed! After finally getting it out, my advice to those with the Late 2011 model is to use a spudger to loosen the edges of the connector then lift the connector straight up to get it out safely.
Dave - Contestar
I replaced the display on my late 2011 model and noticed that it was quite different than the tutorial given here so I detailed all the differences to help others with late-2011 models on my blog: http://johnfixesstuff.blogspot.com/2014/...
jmueller -
Before disconnecting the camera cable, a small plastic retainer stuck to the logic board must first be moved out of the way.
  • Before disconnecting the camera cable, a small plastic retainer stuck to the logic board must first be moved out of the way.
  • Use the tip of a spudger to push the small plastic cable retainer away from the camera cable socket for enough clearance to remove the camera cable.
Agregar Comentario
Pull the camera cable toward the optical drive opening to disconnect it from the logic board.
  • Pull the camera cable toward the optical drive opening to disconnect it from the logic board.
  • The camera cable socket is very fragile. Do not apply any upward force to this socket, as it may break off the logic board. Pull the camera cable parallel to the face of the logic board.
  • For Late 2011 models, the camera connector plugs straight down into the motherboard—to remove this connector, gently lift it straight up.
My A1297 looks very different from this picture. The camera cable is not affixed with any plastic piece, it was a small blade connector that was at the top left corner of the mobo. It is removed by pulling it horizontally from the socket. It is my least favorite type of cable connection and the one most likely to be bent in the process (or the socket, be careful).
maccentric - Contestar
My mid2010 1297 was also different. Camera cable is per "step 7" here (http://www.shareyourrepair.com/2014/11/h...). Very very delicate.
Carefully pull the Bluetooth cable toward the fans to disconnect it from the Bluetooth board.
  • Carefully pull the Bluetooth cable toward the fans to disconnect it from the Bluetooth board.
  • Pull the cable parallel to the face of the optical drive.
Once again, this step, and the rest that follow regarding the bluetooth board, bears no resemblance to my A1297. Luckily, it looks like things have been made simpler. Remove the camera cable from it's socket, the bluetooth cable (flat, black, just shy of .5" wide), and the DVD cable from their sockets. Remove the screw from the top right side of the black plastic piece that holds the bluetooth board and all the skinny black cables. Remove the screw at the top of this piece that fastens to the hinge (look for the shiny metal). Then just lift that piece out of the way, remove the 3 screws holding the DVD in place, and you can pull the drive out (I just grab it by the orange cable and pull it out, but that's probably not the preferred method).
Again, also mid 2010 A1297, the large flat cable crosses the drive. Remove on logic board end by prying carefully "UP" away from the board. Step 8 here: (http://www.shareyourrepair.com/2014/11/h...)
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Use the flat end of a spudger to peel the thin plastic cover off the top and sides of the Bluetooth board housing.
  • Use the flat end of a spudger to peel the thin plastic cover off the top and sides of the Bluetooth board housing.
Is there any real need to remove these cables from the Bluetooth Board? Are you not able to simply conduct step 14 here instead, leaving cables in place, therefor not jeopardising integrity of the housing?
Does the indicated Dual HDD housing replicate the holes found on the Optical Drive to allow this?
Fletch Christian - Contestar
mid 2010 A1297 again. Different configuration. I had a black plastic housing along this whole side. The large flat ribbon connects to it and I LEFT THE RIBBON IN PLACE on this housing. I removed 3 screws here to allow this black housing to be lifted off the drive and to the side, along with the camera line (held down by 3rd screw). When REPLACING this black housing after installation is complete, note there is a small tab on the disc slot side of the housing that needs to be inserted into a slot for correct placement. Then SKIP TO STEP 10 on this IFIXIT tutorial.
Use the flat end of a spudger to pry the Bluetooth antenna connector up and off its socket on the Bluetooth board.
  • Use the flat end of a spudger to pry the Bluetooth antenna connector up and off its socket on the Bluetooth board.
Agregar Comentario
If present, remove the small piece of EMI foam near the Bluetooth board. De-route the camera cable from the slot molded into the Bluetooth board housing.
  • If present, remove the small piece of EMI foam near the Bluetooth board.
  • De-route the camera cable from the slot molded into the Bluetooth board housing.
Agregar Comentario
Use the flat end of a spudger to pry the optical drive connector up and out of its socket on the logic board.
  • Use the flat end of a spudger to pry the optical drive connector up and out of its socket on the logic board.
Agregar Comentario
Remove the three 3.5 mm Phillips screws securing the optical drive to the upper case.
  • Remove the three 3.5 mm Phillips screws securing the optical drive to the upper case.
  • To remove the screw closest to the battery, it may be helpful to use a T6 Torx screwdriver to first remove the upper case bracket directly above it.
Agregar Comentario
Remove the optical drive from the upper case, minding any cables that may get caught.
  • Remove the optical drive from the upper case, minding any cables that may get caught.
Agregar Comentario
Use the flat end of a spudger to lift the subwoofer &amp; right speaker connector out of its socket on the logic board.
  • Use the flat end of a spudger to lift the subwoofer & right speaker connector out of its socket on the logic board.
  • Pry up from beneath the wires.
Agregar Comentario
Use an iPod opening tool or another soft thin-edged tool to carefully lift up a corner of the &quot;Warning: Do not remove the battery&quot; sticker off the right speaker/subwoofer enclosure. Peel the sticker off the right speaker/subwoofer enclosure.
  • Use an iPod opening tool or another soft thin-edged tool to carefully lift up a corner of the "Warning: Do not remove the battery" sticker off the right speaker/subwoofer enclosure.
  • Peel the sticker off the right speaker/subwoofer enclosure.
  • It is not necessary to peel the sticker off the battery.
Agregar Comentario
Remove the following three screws securing the subwoofer &amp; right speaker to the upper case:
  • Remove the following three screws securing the subwoofer & right speaker to the upper case:
    • One 2.6 mm Phillips screw
    • Two 12.3 mm Phillips screws
Agregar Comentario
Hold the battery sticker out of the way as you remove the subwoofer &amp; right speaker from the upper case.
  • Hold the battery sticker out of the way as you remove the subwoofer & right speaker from the upper case.
Agregar Comentario
Conclusión
5 personas más completaron esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 4
Últimos 7 Días: 25
Últimos 30 Días: 125
Todo El Tiempo: 17,745
