Saltar al contenido principal
MacBook Pro 17" Unibody Hard Drive Removal/Installation Replacement
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. MacBook Pro 17" Unibody Hard Drive Removal/Installation Replacement, Hard Drive Removal/Installation: paso 1, imagen 1 de 1
    • Turn the computer over and remove all of the screws that holds together the bottom of the case.
    • The bottom left three screws are longer. Set those aside for reassembly
  2. MacBook Pro 17" Unibody Hard Drive Removal/Installation Replacement: paso 2, imagen 1 de 1
    • Here are the three larger screws. The smaller ones fit the remaining holes
  3. MacBook Pro 17" Unibody Hard Drive Removal/Installation Replacement: paso 3, imagen 1 de 1
    • Delicately lift the case off. The hard drive is visible. There is a bracket with two black screws holding it in place. Remove the bracket and you have access to the hard drive.
    • Remove the interface from the SATA drive and leave the ribbon connected to the mobo.
Conclusión
19 personas más completaron esta guía.
jgreenmun
Miembro Desde 03/05/12
876 Reputación
1 Guía escrita
Un comentario
do you know if it's posible to upgrade the RAM memory in this particular model ?
Thanks for the guide,
Fons - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 14,525
