Saltar al contenido principal
MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Upper Case Replacement
Qué necesitas
  1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Upper Case Replacement, Battery: paso 1, imagen 1 de 1
    • Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
  2. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Upper Case Replacement, RAM Shield: paso 2, imagen 1 de 1
    • Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
  3. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Upper Case Replacement: paso 3, imagen 1 de 1
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
  4. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Upper Case Replacement, Upper Case: paso 4, imagen 1 de 1
    • Remove the three Phillips screws in the battery compartment near the latch. Apple was nice enough to tilt these screws at a slight angle to make them easier to remove. On the A1261 these screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
  5. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Upper Case Replacement: paso 5, imagen 1 de 1
    • Remove the following six screws:
    • Two 14.5 mm T6 Torx screws on either side of the RAM slot.
    • Four 3.4 mm Phillips screws along the hinge.
  6. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Upper Case Replacement: paso 6, imagen 1 de 1
    • Remove the four 3.4 mm Phillips screws on the port side of the computer.
  7. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Upper Case Replacement: paso 7, imagen 1 de 1
    • Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
  8. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Upper Case Replacement: paso 8, imagen 1 de 1
    • Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
  9. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Upper Case Replacement: paso 9, imagen 1 de 1
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up the back of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
  10. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Upper Case Replacement: paso 10, imagen 1 de 1
    • Disconnect the trackpad and keyboard ribbon cable from the logic board.
    • Remove the upper case.
  11. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Upper Case Replacement, Upper Case: paso 11, imagen 1 de 1
    • Use a spudger to pry up the translucent plastic sheath covering the keyboard connector.
  12. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Upper Case Replacement: paso 12, imagen 1 de 1
    • Use the tip of a spudger to flip up the black plastic flaps locking down the keyboard and keyboard backlight ribbon cables.
  13. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Upper Case Replacement: paso 13, imagen 1 de 1
    • Slide the orange keyboard backlight ribbon out of its connector.
  14. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Upper Case Replacement: paso 14, imagen 1 de 1
    • Peel up the orange tape covering the keyboard backlight connector.
  15. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Upper Case Replacement: paso 15, imagen 1 de 1
    • Use the tip of a spudger to flip up the brown plastic flap locking down the keyboard backlight ribbon cable.
  16. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Upper Case Replacement: paso 16, imagen 1 de 1
    • Use a spudger or your finger to slide the keyboard backlight ribbon out of its connector.
  17. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Upper Case Replacement: paso 17, imagen 1 de 1
    • Carefully peel up the orange ribbon cable which carries the power and sleep signals.
  18. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Upper Case Replacement: paso 18, imagen 1 de 1
    • Peel up the two black protective sheaths on the bottom of the keyboard. It is not necessary to fully remove these, but only to peel them back enough to access the screws beneath.
  19. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Upper Case Replacement: paso 19, imagen 1 de 2 MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Upper Case Replacement: paso 19, imagen 2 de 2
    • If you have a MacBook Pro 17" Model A1151 or A1212, refer to the first picture to remove the ten identical Phillips screws attaching the keyboard to the casing.
    • If you have a MacBook Pro 17" Model A1229, refer to the second picture to remove the twelve identical Phillips screws attaching the keyboard to the casing.
  20. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Upper Case Replacement: paso 20, imagen 1 de 2 MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Upper Case Replacement: paso 20, imagen 2 de 2
    • If you have a MacBook Pro 17" Model A1151 or A1212, refer to the first picture. There are four locking tabs along the back edge of the keyboard holding it in place. These tabs must be straightened before you can remove the keyboard.
    • If you have a MacBook Pro 17" Model A1229, refer to the first picture. There are six locking tabs along the back edge of the keyboard holding it in place. These tabs must be straightened before you can remove the keyboard.
  21. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Upper Case Replacement: paso 21, imagen 1 de 1
    • The first frame shows a tab in the "locked" position and the second frame shows the same tab in the "unlocked" position.
    • Use needlenose pliers or a spudger to bend each of the four tabs so that they are all in the "unlocked" position.
  22. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Upper Case Replacement: paso 22, imagen 1 de 1
    • Slide the keyboard ribbon out of its connector.
    • If the keyboard ribbon won't slide out, make sure that the black plastic flap holding the ribbon in place is vertical.
  23. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Upper Case Replacement: paso 23, imagen 1 de 1
    • Place the upper casing on its edge and use a spudger to push the keyboard away from the casing, poking the spudger through the central keyboard screw hole. Grasp the keyboard as it separates from the casing.
  24. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Upper Case Replacement: paso 24, imagen 1 de 1
    • Maintaining your hold on the keyboard, lay the casing flat and gently bow the keyboard until the two tabs on either side of the keyboard come free.
    • Slide the keyboard away from the trackpad and out of the upper case.
  25. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Upper Case Replacement: paso 25, imagen 1 de 1
    • Upper case remains.
    • To install your replacement upper case, install your current keyboard into the replacement case and reassemble your computer.
Conclusión
16 personas más completaron esta guía.
iRobot
Miembro Desde 09/24/09
1 Reputación
636 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 19
Todo El Tiempo: 24,157
