Introducción
Replacing a defective fan is pretty easy and will keep your laptop running cool.
Remove the following ten screws securing the lower case to the upper case:
    • Seven 3 mm Phillips screws.
Agregar Comentario
Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case. Remove the lower case and set it aside.
  • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
Agregar Comentario
Use a spudger to pry the fan connector straight up off the logic board. It is useful to twist the spudger axially from beneath the fan cable wires to release the connector. The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
  • Use a spudger to pry the fan connector straight up off the logic board.
  • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
  • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
Agregar Comentario
Remove three T6 Torx screws securing the right fan to the logic board and upper case.
  • Remove three T6 Torx screws securing the right fan to the logic board and upper case.
Agregar Comentario
Lift the right fan out of the upper case.
  • Lift the right fan out of the upper case.
Agregar Comentario
Conclusión
53 personas más completaron esta guía.
Merci à iFixIt pour la qualité des pièces fournies et la rapidité à laquelle elles ont été expédiées.
Merci à Walter pour la clarté de son tuto, et aux traducteur pour la traduction !
Que du bonheur !
Fabrice CROMBEZ - Contestar
Hello Walter, I have a mid 2009 macbook pro 15” and it has only one fan. I need to replace it. Which one should I buy?
bikkon yestal - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 7
Últimos 30 Días: 31
Todo El Tiempo: 17,674
