Saltar al contenido principal
MacBook Pro 15" Unibody Mid 2009 LCD Replacement
Qué necesitas
  1. MacBook Pro 15" Unibody Mid 2009 LCD Replacement, Lower Case: paso 1, imagen 1 de 1
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 2, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 2, imagen 2 de 2
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody Mid 2009 LCD Replacement, Battery: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    P6 Pentalobe Screwdriver 2009 15" MacBook Pro Battery
    $5.49
    Comprar
    • Remove the two 5-Point Pentalobe screws along the top edge of the battery.
    • You do not necessarily have to follow steps 3-6 to remove the battery in order to replace the hard drive. However it is recommended to remove all power sources from electronics before working on them.
  4. MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 4, imagen 1 de 1
    • Use the tip of a spudger to bend back the finger of the "Warning: Do not remove the battery" sticker while you remove third five-point Pentalobe screw hidden underneath.
  5. MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 5, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 5, imagen 2 de 2
    • Lift the battery by its plastic pull tab and slide it away from the long edge of the upper case.
    • Do not try to completely remove the battery just yet.
  6. MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 6, imagen 1 de 1
    • Tilt the battery back enough to access the battery cable connector.
    • Pull the battery cable connector away from its socket on the logic board and remove the battery from the upper case.
    • If you're installing a new battery, you should calibrate it after installation.
  7. MacBook Pro 15" Unibody Mid 2009 LCD Replacement, Display: paso 7, imagen 1 de 1
    • Apple sticks a small strip of clear plastic with adhesive applied to one side of the logic board behind the camera cable connector to keep it in its socket. When moving it out of the way, be sure not to break any surface-mount components off the logic board.
    • Use the tip of a spudger to rotate the plastic retainer away from the camera cable connector.
  8. MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 8, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 8, imagen 2 de 2
    • Pull the camera cable away from its socket on the logic board.
    • Pull the connector parallel to the face of the logic board, not straight up.
  9. MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 9, imagen 1 de 1
    • Peel the camera cable off the adhesive securing it to the body of the optical drive.
  10. MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 10, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 10, imagen 2 de 2
    • This step is only required if you have an anti-glare display. If you have a glossy display, skip to step 12.
    • Disconnect the Bluetooth cable by pulling the male end straight away from its socket.
    • Use the flat end of a spudger to pry the Bluetooth antenna cable up from its socket on the board.
  11. MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 11, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 11, imagen 2 de 2
    • Remove the two 8 mm Phillips screws securing the Bluetooth/camera cable retainer to the upper case.
    • One of the screws may remain captive in the Bluetooth/camera cable ground loop. If replacing the display, be sure to transfer this screw to the new unit.
    • Lift the Bluetooth board/cable retainer assembly out of the upper case.
  12. MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 12, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 12, imagen 2 de 2
    • This step is only for glossy display machines. If you have an anti-glare display, skip this step.
    • Remove the two 8 mm Phillips screws securing the camera cable retainer to the upper case.
    • One of the screws may remain captive in the camera cable ground loop. If replacing the display, be sure to transfer this screw to the new unit.
    • Lift the camera cable retainer out of the upper case.
  13. MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 13, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 13, imagen 2 de 2
    • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
  14. MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 14, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 14, imagen 2 de 2
    • Remove the single 7 mm Phillips screw securing the display data cable retainer to the upper case.
    • This screw may remain captive in the display data cable ground loop. If replacing the display, be sure to transfer this screw to the new unit.
    • Remove the display data cable retainer from the upper case.
  15. MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 15, imagen 1 de 1
    • Be sure the display data cable lock is rotated toward the DC-In board before proceeding.
    • Pull the display data cable connector straight away from its socket.
    • Make sure to pull the connector parallel to the face of the logic board, not straight up from its socket.
  16. MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 16, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 16, imagen 2 de 2
    • Remove the outer two T6 Torx screws securing both display hinges to the upper case (four screws total).
  17. MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 17, imagen 1 de 1
    • Open your MacBook Pro so the display is perpendicular to the upper case.
    • Place your opened MacBook Pro on a table as pictured.
    • While holding the display and upper case together with your left hand, remove the remaining T6 Torx screw from the lower display bracket.
  18. MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 18, imagen 1 de 1
    • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
    • Remove the last remaining T6 Torx screw securing the display to the upper case.
  19. MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 19, imagen 1 de 3 MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 19, imagen 2 de 3 MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 19, imagen 3 de 3
    • Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
    • Rotate the display slightly away from the upper case.
    • Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
  20. MacBook Pro 15" Unibody Mid 2009 LCD Replacement, Front Display Glass: paso 20, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 LCD Replacement, Front Display Glass: paso 20, imagen 2 de 2
    • In the following steps, you will use a heat gun to soften the adhesive securing the outer black border around the underside of the front glass panel to the display. The area the adhesive is applied to is shown in red in the second picture.
    • Before starting, be sure to clean the display glass with lint-free cloth moistened with a mild solution; it will make the suction cup adhere better, and will make checking for dust on reassembly easier
    • With the heat gun set to low, start by heating the outer black border near the upper right corner of the glass panel.
    • Always aim the heat gun away from the soft rubber strip around the display glass. Heating the rubber will cause it to melt slightly, turning its finish from matte to glossy. Touching overheated rubber can cause it to permanently deform.
    • Due to the heat applied, it is normal for a layer of condensation to develop on the inside of the glass panel and/or the outside of the LCD. It can be removed with glass cleaner once the glass is separated from the display.
  21. MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 21, imagen 1 de 3 MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 21, imagen 2 de 3 MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 21, imagen 3 de 3
    Heavy-Duty Suction Cups (Pair)
    $14.95
    Comprar
    • With the panel sufficiently heated, fasten a heavy-duty suction cup near the upper right corner of the display glass.
    • Don't fasten the suction cup on top of the rubber strip around the edge of the display glass.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • Slowly and gently pull the corner of the display glass up off the display assembly.
    • If only the top edge of the glass lifts up (as seen in the third picture), repeat steps one and two until you can lift up the corner of the panel.
  22. MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 22, imagen 1 de 3 MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 22, imagen 2 de 3 MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 22, imagen 3 de 3
    • Gently lift the corner of the display glass enough to insert a spudger between it and the display assembly.
    • Use the flat end of a spudger to gently pry up the adhesive securing the front glass to the display.
    • Pry up the glass panel a few inches away from the upper right corner along the top and right edges of the display.
  23. MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 23, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 23, imagen 2 de 2
    • Use a heat gun to soften the adhesive under the black strip along the right side of the front glass panel.
    • Attach a suction cup along the right side of the front glass panel.
    • Pull up on the glass panel while you use the flat end of a spudger to separate it from the rest of the display assembly.
    • Continue working along the right edge of the front display glass until it is separated from the display.
    • It may be helpful to use a guitar pick or another thin plastic object to keep the upper right corner of the front glass panel from sticking back down to the display assembly.
  24. MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 24, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 24, imagen 2 de 2
    • Use your heat gun to soften the adhesive under the black strip along the top edge of the glass display panel.
    • Attach a suction cup near the top edge of the glass display panel and use it to pull the glass panel up off the display.
    • Work along the top edge of the glass panel, carefully using the flat end of a spudger to separate the adhesive if necessary.
  25. MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 25, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 25, imagen 2 de 2
    • Use a heat gun to soften the adhesive under the black strip near the upper left corner of the glass display panel.
    • Attach a suction cup near the upper left corner of the glass display panel.
    • Pull up on the suction cup and use the flat end of a spudger to carefully pry the glass display panel out of the display assembly.
    • Once the upper left corner has been separated from the display, it may be helpful to use a guitar pick or another thin plastic object to keep the glass from sticking back down to the display assembly.
  26. MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 26, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 26, imagen 2 de 2
    • Use a heat gun to soften the adhesive under the black strip along the left side of the front glass panel.
    • Attach a suction cup along the left side of the front glass panel.
    • Continue working along the left edge of the front display glass until it is separated from the display.
  27. MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 27, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 27, imagen 2 de 2
    • Now that the top, left, and right edges of the glass are free from the display, slowly lift the top edge of the glass panel and gently rotate it out of the display.
    • If necessary, use the flat end of a spudger to free the bottom edge of the glass display panel from the display assembly.
    • Before reassembling, be sure to clean both the inside of the glass display panel and the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is on.
  28. MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 28, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 28, imagen 2 de 2
    • Insert the edge of a plastic opening tool between the display glass and the camera bracket, and run it around the camera bracket to separate it from the display glass.
    • Do not forget to stick the camera bracket down to the new front display glass before reassembly.
  29. MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 29, imagen 1 de 3 MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 29, imagen 2 de 3 MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 29, imagen 3 de 3
    • During the glass removal process, the camera cable may stick to the adhesive on the glass panel, disconnecting it from the camera board as the panel is lifted. If your camera cable is still connected to the camera board, skip this step.
    • To reconnect the cable, first use the tip of a spudger to remove the piece of foam tape over the camera cable ZIF socket.
    • Use the tip of a spudger to flip up the ZIF cable retainer on the camera cable socket.
    • Insert the camera cable into its socket on the camera board and use the tip of a spudger to snap down the ZIF cable retainer, locking the cable in place.
    • Reapply the piece of tape covering the camera cable socket.
  30. MacBook Pro 15" Unibody Mid 2009 LCD Replacement, LCD: paso 30, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 LCD Replacement, LCD: paso 30, imagen 2 de 2
    • Slide the clutch cover toward the right edge of the display.
    • The clutch cover will move approximately .25" and stop. Do not force it too far to the right.
    • When reinstalling the clutch cover, be sure to slip it over the components protruding from the lower edge of the display about .25" to the right of its final installed position on the display.
  31. MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 31, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 31, imagen 2 de 2
    • Starting at its far left end, rock the clutch cover along its long axis while pulling it away from the clutch hinge.
    • Working from right to left, carefully continue to release and lift the clutch along the lower edge of the display assembly.
    • Lift the clutch cover up off the front bezel and set it aside.
    • When reinstalling the clutch cover, be sure to widen the opening when slipping it over the small black plastic cosmetic cover that fills the open end of the clutch cover when it is in place. The cosmetic cover has very thin and delicate plastic arms that hold it to the right clutch hinge.
  32. MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 32, imagen 1 de 1
    • Remove the six 2.9 mm Phillips screws securing the LCD panel to the front bezel.
  33. MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 33, imagen 1 de 1
    • Pull the LCD toward the top edge of the display to slide the circuitry along its lower edge out of the recess in the aluminum display assembly.
    • It may be helpful to use one hand to feed the display data cable through its channel in the aluminum display assembly as you pull the LCD toward the top edge of the display with the other hand.
  34. MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 34, imagen 1 de 1
    • Peel the piece of tape covering the display data cable connector away from the edge closest to the LCD.
  35. MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 35, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 LCD Replacement: paso 35, imagen 2 de 2
    • Use the tip of a spudger to flip up the thin steel retaining clip securing the display data cable to its socket on the LCD.
    • Pull the display data cable straight away from its socket on the LCD.
    • Lift the LCD out of the display assembly and set it aside.
    • If you are replacing the LVDS/display data cable, simply de-route it from its slot cut into the display casing.
Conclusión
34 personas más completaron esta guía.
9 comentarios
General : Is there instruction available if you have the anti-glare displays? Or do you officially recommand to change the LCD AND THE GLASS, if we want to keep the anti-glare displays? Can we order the anti-glare displays here? Thanks! =)
ginacouture - Contestar
I have a Macbook Pro Unibody 15" (2009) can I switch the whole display and lid with a Macbook Pro 15" (2011)and is the airport card piece for both models in the display?...
MichaelJrRekson - Contestar
No, you can’t, because of the camera cable connector, different from the 2011 model.
Fran Werttt -
Where can i get the metal frame that runs through the LCD assembly.
Brayan Almonte - Contestar
Same question for me!
Fran Werttt -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 57
Todo El Tiempo: 72,488
